Old 04-22-2014, 09:15 PM   #1
Replacing bedroom slide actuator 2014 Rockwood 8289
Actuator gearbox failed - broken tooth. Advice from anyone about replacing electric motor/gearbox unit on bedroom slide?
ronkosar is offline   Reply With Quote
Old 04-22-2014, 09:40 PM   #2
Need to replace this slide-out actuator with broken teeth in gearbox for our 2014 Rockwood 8289.
Name:	ImageUploadedByForest River Forums1398220630.972362.jpg
Old 04-28-2014, 03:50 PM   #3
tmhyer's Avatar
Is it not under warranty?
Sent from my SCH-I545 using Forest River Forums mobile app
tmhyer is offline   Reply With Quote
Old 04-28-2014, 03:54 PM   #4
Herk7769's Avatar
Should still be under warranty.
Here are some "how to" files and sources for the motor assembly:
NORCO ACCU SLIDE 12 V ELECTRIC SLIDEOUT MOTOR FOR RV | eBay
Name:	Flex Drive Tool.jpg
ID:	51158   Click image for larger version
Name:	Wardrobe Slideout Motor.jpg
HAM CALLSIGN - KC3FFW
Old 04-28-2014, 04:17 PM   #5
RFKosar's Avatar
Thanks for good info.
Yes still under warranty but on a extended trip 1600 miles from dealer. Don't want to take it to a FR warranty shop and be stranded for weeks or month or more in a hotel.
So purchased motor/gearbox direct from FR Parts, shipped express. Concerned I will misalign chain/cables after replacing the motor/gearbox.
Good news is Rockwood warranty dept agreed to cover under warranty (reimburse) cost of motor, shipping and labor for repair.
Think I found a nearby mobile repair service experienced with BAL Accu-Slide room slideouts. I will probably have to pay for service call charge. Fingers crossed that RV technician can actually fix it.
RFKosar is offline   Reply With Quote
Old 04-28-2014, 04:25 PM   #6
Alignment should be easy enough if you measure from an edge to the chain and just unhook the old and hook the new one up. I would imagine there is a little play in the mounting holes.
Old 04-28-2014, 04:37 PM   #7
RFKosar's Avatar
I'll need a pair of screw jacks to support weight of extended slide-out. Old Coot's suggestion of measuring position of drive chain is good. I can mark exact spot where sprocket gear engages drive chain by small nylon zip ties in chain links touching sprocket teeth.
Plan coming together.
Old 04-28-2014, 04:42 PM   #8
Use your awning poles to hold the slide.
Old 05-04-2014, 06:18 AM   #9
Fixed! Not too difficult. Thx for suggestions.
Old 06-06-2014, 03:10 PM   #10
PhoneDude 8289's Avatar
Anybody open up the gear box on the norco motor & gear box combo to see what gear has broken teeth? Can this gear be replaced? How about a spare set of gears for this gear box, can't be that expensive.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
2014, bed, bedroom slide, rockwood, roo, slide
