Old 06-24-2013, 12:10 PM   #1
Rockwood Signature Ultralite 5th wheel slide and stabilizer problem
Hi
I have a question. I have the RW 5th wheel and on a trip this past weekend, both the front stabilizer and bedroom slide out failed to work when we were trying to leave the camp site. I used the hand crank to bring up the stabilizer and a cordless drill to crank in the slide so we made it out.
I checked the fuses under the fridge and they are all fine. I looked in the front battery compartment and cannot find a re set or fuse box. I also checked around the hitch area and not luck either.
Any ideas ?
Russell
russellspence is offline   Reply With Quote
Old 06-25-2013, 10:31 AM   #2
Fulltime family RVer
Dead battery? I know people have also mentioned in-line fuses for the slides.. maybe if you trace the wires you'll find one?
(Really, I don't know - this is more of a bump for your post.)
Old 07-14-2013, 05:14 PM   #3
CZNEDY's Avatar
Russ, I have the flagstaff sister model and the same thing just happened to us today. Living room slide went in OK, bedroom slide didnt work and the front landing gear didnt work. Did you ever figure anything out on yours?
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
