Old 07-08-2015, 10:59 AM   #1
Rockwood Slide Inop
I have a 2008 Rockwood 8317 SS. Last time out, the slide retracted but did not click per usual. Since then the switch doesn't respond. Can't hear anything when the switch is activated. I had to use the manual hand crank to operate the slide. All fuses are good. Tried a different battery and no luck.
kharris111 is offline   Reply With Quote
Old 07-08-2015, 11:52 AM   #2
fonzie's Avatar
Possibly a fuse or mini-breaker underneath trailer near tongue that is burnt or tripped. Re-set by pushing small black button (if you have) or change fuse.
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 07-08-2015, 02:09 PM   #3
Fonze, thanks for the suggestion. I didn't know there was an external relay. I'll take a look.
rockwood, slide
