Old 03-16-2014, 01:44 PM   #11
Bubbamace's Avatar
An update. I got my motor home back after one month and the hose has been replaced. Of course the hose was not routed like the stock hoses along the frame. The hose is wrapped around the frame and not secured properly. Also, the water tank was removed and when it was put back in the cover was put in inside out with the staples facing outward. The insulating foam was stuck back in the holes where the drain hoses come out of the bottom of the motor home. By the time I got the motor home the foam was hanging out of the holes.
I wouldn't have found out about the routing of the hose or the foam had I not been installing an inverter and routing wiring underneath the coach. All I can say is do not let McMahon's RV in Westminster, Ca. work on your coach. My "Tech" was Diego and I can say he did one of the sloppiest jobs on my coach I have ever seen. I have been camping since being a kid when my dad had a camper. We have had several trailers, a couple of campers, and several motor homes and never had this poor service.
Bubbamace is offline   Reply With Quote
slide, slide out
