Old 04-30-2016, 02:37 PM   #1
Schwinn slide controller location
Any ideas where the slide controller is located on a 2011 Cherokee Grey wolf 26rl? Forest River has been no help.
hotrod56 is offline   Reply With Quote
Old 04-30-2016, 02:44 PM   #2
raspivey's Avatar
On my Mini Lite, it was on the forward wall in the pass through storage. Seems they like to stick them there on several models, so that's where I'd start.
Old 04-30-2016, 04:44 PM   #3
World Wide Wanderer
wahoonc's Avatar
No clue on your specific model, but I would look in the storage areas first, look for plastic "boxes" mounted the walls or ceilings of your storage areas. The actual controller is just a bit bigger than a pack of cigarettes.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 05-02-2016, 08:56 PM   #4
Too Tall's Avatar
Yes that's where mine is also its behind piece of wood so you have to remove the wood with screwdriver first
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 05-02-2016, 09:10 PM   #5
raspivey's Avatar
Must have changed that up a little. I've got a 2104S also (2014). It's got the wood divider, but the forward one is on a rail and slides out of the way. Just wish the rear one covering the water heater was too.
Old 05-02-2016, 09:20 PM   #6
Like he said. If you've got what looks like a cupboard door, but it has no knob and an extra hinge on the side the knob should be on, it's a good bet it's behind there. (If not, your HW bypass valves, or your water pump, or your water filter, are probably there - )
2011 Traverse LT, 3.6L, FWD
cat, controller, location, slide
