Old 06-07-2018, 12:14 PM   #1
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Schwintek slide alignment
I am trying to realign the Schwintek Slide on our Columbus 383fb....one end lacks about an inch drawing up tight when it's closed.....I've gone through the procedure that Schwintek recommends...open the slide out .... bring it back in 8-10 inches and repeat that a minimum of 3-4 times....that is suppose to synchronize the two motors and bring the slide in evenly....it's not happening...so, is there anything wrong with disengaging the motor on the end that's not coming in, manually push the slide in about an inch on that end, and then re-engaging the motor?....comments from those with this type slide experience would be appreciated.
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi...
2017-65 nights/6992 mi.; 2018-47 nights/7376 mi; 2019-56 nights/6987 miles; 7 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 06-07-2018, 12:42 PM   #2
You can do that . real pain to get to the motors sometimes . i would try to do opposite what your doing fully retract the slide then out 6" to 8 " and back in this normally works .
MR.M is offline   Reply With Quote
Old 06-07-2018, 04:32 PM   #3
Solved my slide problem.....found a TV/Cable wire wedged up under the floor of the slide...it had somehow gotten up under the slide track and was restricting the slide from pulling all the way in on the lower right corner.
Old 06-07-2018, 05:13 PM   #4
Kasual Kamper
Glad it was an easy fix.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
alignment, slide
