10-04-2016, 02:49 PM
schwintek slide motor repair
I had a problem this summer when one of the motors would move 2" and stop. did a manual override at the controller and the motors worked fine. So being cheep i pulled the motor out and found the circuit board is very simple, tested all the wiring it was fine. The 2 little "Hall" sensors had failed ordered 5 from amazon (Honeywell SS41 Hall effect sensor) $5.32. Soldered them in and replaced the motor works like new. Hope this helps. A Lot better than a $150.00 motor. Fyi the original sensors are the cheapest available not surprised.
10-13-2016, 11:09 AM
My slide seems to be doing the same thing. Do these Hall sensors go on the motor or the control board?
10-13-2016, 09:31 PM
The sensors are on the motor. Under the plastic cover
10-15-2016, 01:06 PM
I have not had time to repair the motor yet and wanted to go camping tomorrow. Is there any way to get the slide out? I was able to get it in using the electronic overide but I don't think the overide works going out. Does anyone know for sure?
10-15-2016, 06:45 PM
I am pretty sure it works both ways, but why not try it out at home first to be sure.
10-15-2016, 07:16 PM
Thanks for sharing and posting, I will definitely try that when the motor eventually quits.
2015 Solera 24r
2017 Jeep Wrangler
10-16-2016, 06:35 AM
Ok, I got it to work going both ways. It is more difficult when the slide is in because I have to use a 3/16 inch dowel rod that is about three feet long to be able to reach the little button on the controller. Just waiting on the sun to come up before heading out.
10-16-2016, 08:45 AM
I am curious, where is your controller located, ours is under the raised floor the sofa sits on and almost in the middle of the sofa, can't even access it, dumbest place ever to put it
10-16-2016, 08:58 AM
Ours is under the sofa moved it to under the sofa for easer access
10-16-2016, 09:31 AM
I have thought of moving our's out from under the sofa, but don't want to do anything to void the warranty, we have already had the slide fixed 3 times since we bought it new in July. Hopefully it is fixed for good now. But since I cannot access the controller, we had to use brute force with 3 guys to push the slide in to get it to the dealer for repair. Since yours was under the sofa too, do you happen to have a picture of where you have it now?
10-16-2016, 09:44 AM
Thanks Jc! Awesome tip! We encountered exact same symptom on the 1st
stop of a planned 3 week trip around Florida last January. We limped along with the slide stuck in for half the trip until someone here on the forum sent me a U tube video that showed how to put the board in override. We were
able to use the slide the last 2 stops thankfully!
Got dealer to show me how to remove a motor or uncouple a motor so the
slide can be more easily pushed if necessary.
Always glad to read about cheaper work arounds for expen$ive parts!
Thankfully my control board is accessible inside my front pass thru storage!
Happy Trails!
Peace!
Dan & Rita D
10-21-2016, 02:04 PM
Another question for you. Did you remove the circuit board or solder them with the board in place. If you removed it does the little disk on the top of the motor shaft just pry off? If so does it need alighnment marks to put it back in the same position? Do the little nylon brackets come with the new sensors?
Thanks again, Mike
10-21-2016, 09:46 PM
The magnet slides off and not position sensitive. The plastic covers fit the new sensors fine. I did not remove the board from the motor little tricky to solder but doable
10-22-2016, 08:38 AM
I have a 2015 Berkshire 34qS. Does anyone know where the slide out fuses are?
10-24-2016, 05:31 AM
The fuses should be in your main fuse panel the controller has no internal fuses. Hope that helps
10-31-2016, 08:26 AM
I finally received my sensors from Arrow.com, the good news is they were only $.75 ea. I soldered them in place and installed the motor back in the camper wall. I pushed the slide button and no good. So I pull the motor and do some tracing and find the circuit board is at fault. One wire I had to remove and clean the contacts and resolder. Another wire required drilling a new hole and soldering and the third required a short jumper. I put it back together last night and it works fine for now. I have little faith in the longevity of the board however. I don't suppose I could buy just the board anywhere? My other thought was maybe I could find a motor that had gone bad and take the board out of it.
10-31-2016, 03:00 PM
I just ordered a new motor on ebay for $49 with free shipping. I plan to keep it in the camper for a spare. If I had seen that sooner I wouldn't have spent time repairing the old one. Oh well, it was a good learning experience.
