Old 03-30-2014, 08:15 PM   #21
slide outs
Hi all. Hopefully I will never have a slide out problem. If I do, I will first access the control box, press the relay 7 times to see if it activates the slide out. Failing that, I will disconnect the power at the fuse box or battery and try to move the slide out. Failing that, I will remove the set screws and disconnect the motors from the drive shafts to move the slide out. Hopefully something will work. Much appreciated to all those who have replied to this issue. Happy camping everyone!! Hope to meet up with you on the road.
biker2 is offline   Reply With Quote
slide, slide out
