Old 09-01-2015, 12:23 AM   #1
Schwintek slide out recommended maintenance?
What kind of lube and sealant protectant?
2014 Coachmen Apex 249rbs
Tow vehicle 2015 Toyota tundra 5.7 engine
Time_traveler is offline   Reply With Quote
Old 09-01-2015, 04:04 AM   #2
grumpy0374's Avatar
Best to use one of the dry lube spray for the mechanism, don't use anything wet that will attract and keep dust/dirt.
For the rubber and vinyl seals/gaskets, 303 Protectant. Best stuff around, hands down. Contains no petrolium products. Safe for all rubber, vinyl, plastic, and any run-off will not hurt anything.
A bit pricey, but the good stuff usually is.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 09-01-2015, 05:06 AM   #3
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 09-01-2015, 09:31 AM   #4
Old 09-06-2015, 05:47 AM   #5
DavidAndDonna's Avatar
Originally Posted by cpd1343 View Post
Thanks for the video
David & Donna
Crusader 295RST
Dodge 3500 Dually 6.7 Cummins
Dodge 3500 6.4 Hemi
DavidAndDonna is offline   Reply With Quote
Old 09-10-2015, 08:16 PM   #6
Jimsue's Avatar
Oh. So THATS all there is to it. 👌👌👌
Jim
2009 Roo 21 RS
2013 GMC Sierra 1500
Grand Rapids Mi
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
Demco Hijacker Autoslid
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 09-15-2015, 01:40 PM   #7
Commercial Member
Thanks for the link on maintenance.
I have new Coachmen and this is 1st RV with a slide. Am wondering if there is some adjustment. I note the top of the slide is compressing the gasket so there is only 1/8" between the slide and body while the bottom has 1" between the slide and body. It looks like the gears are not properly set in the gear guide such that the top is canted toward the coach.
TOP
Bottom
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
maintenance, slide, slide out
