Old 05-14-2014, 08:14 AM   #21
Originally Posted by LKicklight View Post
Spoke with Lippert Customer Service yesterday, explained to them our problem with our bedroom slide not coming evenly. We were given instructions on how to perform a procedure to get the two slide motors back in sync with one another. We plan to do that this morning as we do not have any fault lights on the control box. Lippert was good at responding to our problem, only hope it works as instructed.
kickster
ps: we are in Wall, SD, moving on to Custer, SD later today...
Good luck with the repair. When you're in the Custer area, make sure you go visit Crazy Horse Mountain. Was lucky years ago to meet Korczak Ziolkowski.
Name:	Neil & Korczak Ziolkowski -Aug1964.jpg
Old 06-01-2014, 08:22 AM   #22
Can I Retire Now?
Hedemark's Avatar
Unhappy Slide-out stuck before first trip.
Just got a 2015 Coachman class A last week, set it up at home, and tried to take our first trip two days ago. The Schwintek slide out wouldn't come back in. It could not go back to the dealer until the slide-out was put back in. Coach-net sent two tractor-trailer mechanics to get the slide-out back in. They were clueless, but that didn't stop them. They spent the first hour analyzing the hydraulic system..... Not realizing that this had an ELECTRIC slide system. I found two Youtube videos showing how to analyze and repair this, and they changed their approach. The Synchronous controller indicated a short circuit in motor #2. Re-setting the controller for a manual override did not work. The two in-wall electric motors had to be removed. This required all of the trim and wooden framework around the slide-out to be removed. These diesel mechanics are not woodworkers. Much of the beautiful trim is busted. Dirty boots on the upholstery. Fins on floor ductwork broken. Heavy woodwork put on the floor, nail side down. Spilled their soda on the floor and counters. One guy wore pajamas. They forgot their electric screw gun, I loaned them mine. Their own truck wouldn't start, so I had to give them a jump. The bill: $315.00 cash, no checks or credit cards accepted. I am advised that I can submit the bill somewhere for reimbursement. We Missed our first trip, reservations cancelled at Park. We might miss our second trip too, depending on what it will take to get new trim. The interior of our 9 day old 2015 Coachman looks horrible, and my wife is crying. A Techie at Coach-net said that they have had some defective wiring harnesses causing the appearance of a short in a motor, and advised that the dealer should test the wiring before replacing a motor. The dealer appears to be first class. I'll find out soon if that is true.
Hedemark is offline   Reply With Quote
Old 06-17-2014, 03:38 PM   #23
Originally Posted by 10x View Post
Good video, anyone know where the controller is on a hyperlite xlr27hfs toyhauler?
I know this is late, but maybe it'll help someone else... I just had the slide on our xlr27flh act up last weekend. The slide was stuck OUT. Finished camping for the weekend, and packing up. The slide would not come in. Called support and they told us to look for the control box. "About the size of 2 cigarette packs".. we search long and hard and found it under the queen bed up front, in the far left-side storage area. It was tough to find the button to "Press 6 times and hold on the 7th time until lights blink" override. But with my sons fingers, we got it.
This allowed us to run the motor and pull in the slide. The override turns off the auto-sensing shutoff when bringing in the slide, so you have to turn it off yourself. It was pretty easy. Got the slide in and it's now at the dealer for service. Hoping it's covered as the trailer is only a few months old.
vincetampa is offline   Reply With Quote
Old 06-17-2014, 08:20 PM   #24
Can I Retire Now?
Hedemark's Avatar
Schwintek
My slideout would not come in. Tried the over-ride, but no luck. A motor was burned out due to a wire getting chaffed by the slideout. You can't override a dead motor. It was a real mess for a Coach Net crew to get the slide back in! Repairs became extensive. This was a new unit.
Old 07-21-2014, 09:13 PM   #25
I'm about to try and locate the motor release screw on my Hyperlite 27' XLR Toyhauler. I've talked to Lippert tech and being stuck at the IN position they say to unplug motors to release magnetic brake and get some buddies to help push out manually to get to the screw which has to be accessed from the outside. Even with a body shop rod jack it won't budge so I plan to make an educated guess and drill a hole thru the outside skin and hope to be able to get to the screw. I'll let you know how that comes out by Wed. or Thursday, I hope.
Fasteel is offline   Reply With Quote
Old 07-21-2014, 11:05 PM   #26
William
WEMig's Avatar
Fasteel, see my comment below. I had the same issue with my slide stuck out and then in while I was on a trip. The screw to release each motor was under the gasket at the top corners of the slides. Try this before you drill through the skin of your camper. Also, you will need several helpers to do this. Two to disengage the motors and at least two to push the slide out or in. Let us know how it goes. The below comment is from a thread about a year ago. There are several threads on this subject.
By the end of that trip, I could get the slide in and out faster than the motors!
"I had the same issue. The brakes on the in wall motor would not disengage following the procedures. I had to remove the gaskets on either side of the motors on the outside. There was one silver screw that enabled access to the motors where I was able to manually disengage them to push the slide in. These directions came from a PT factory rep when we were stuck with the slide out."
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 07-22-2014, 09:30 AM   #27
I haven't crawled up a ladder yet to get a closer look but according to the videos and Lippert tech, the flange of the skin on the slide out is covering up the screw to disengage the motor. Unless it screws in from the top side between the skin flange and the trailer body skin, I think I'll probably have to drill a hole. My understanding is that the screw goes in horizontally from the outside into the square tube that the motor sets in and is , I assume, used as a set screw.
Old 07-22-2014, 08:46 PM   #28
William
WEMig's Avatar
Thats correct, screw is horizontal and should be accessible behind the rubber seal. Once the seal and screw is removed, you can access the gear of the motor. Removing the screw allows you to lift the gear from the track and the slide can be moved.
Old 07-22-2014, 10:09 PM   #29
I have been measuring any reference points I can utilize to narrow down the spot from the outside on the slide out skin overlap area that I figure is as close as I can calculate, the center of the screw to know where to start the hole. I haven't gotten contact again with Lippert tech to see if they can give me some guidance as to the location I will have to center the hole. I have measured height of slide out roof from window edge, top of motor body from roof level of slide out, distance calc. of center to center between the motor shafts, and subtracted that from the overall width of the outside skin. I don't yet know if the screw lines up with the motor shaft center line but I assume it should. I mainly have to figure the height of the screw from the top of the skin panel or maybe from top end of trim behind it that attaches to the main trailer body wall skin, which is fiberglass. If you know that distance to locate the elevation of the screw center that would be great, assuming the 2 trailers are made the same. Thanks for taking the time to reply, I really do appreciate it.
Old 07-23-2014, 02:52 AM   #30
William
WEMig's Avatar
You don't have to drill a hole in your camper. The screw is accessible from the outside. One per motor located at the top corners of the slide.
slide
