01-18-2014, 05:57 PM
Schwintek Slide Problem
On a routine check of my RV, the slide won't go out. It is the Schwintek type slide. I have already read through all the manual & bulletins and watched their youtube videos. I have tried everything they suggested and nothing is working.
When I press the button, I hear both motors whine for a few seconds then stop, so I know the motors are getting power. The controller is giving me a code 8 & 9. If the controller were not getting a signal then the motors should not do anything (code8). If there were a short in the wiring, the fuse would blow and the motor would not do anything (code9).
I bypassed the limit switch just to get things moving and nothing happens. I have released the motor brakes and the slide will not budge. The slide is in the closed position and I can't get at the motors.
Any suggestions?
Is it time to go camping yet?
2012 Wildwood X-Lite 281QB
2011 Ford F150 XLT 5.0L 3.73
01-19-2014, 08:03 PM
I don't know what to tell you to try.But let us know what you find out because I have two Schwintek slide and never know when the info will come in handy.
01-19-2014, 08:27 PM
Infractee
Is there a manual over ride on those so you can crank them out by hand?
01-19-2014, 08:54 PM
Believe you can drop both motors from the engagement position thus freeing the tracks and therefore the slides will move. Motors are dropped from outside by peeling back the wiper seals. This procedure covered by both the manuals and on line. Suggest you contact someone with training to help troubleshoot.
01-20-2014, 07:44 AM
No manual crank for Schwintek slides. However, they have an electronic manual override. You have to find your controller, then watch this video to see how to use the override feature. This video also shows you how to lift motors up to disengage from rack gear so you can slide room in if it is stuck in out position.
Lippert University on youtube and lci1.com have a lot of good info for the various Lippert made components and assemblies on your RV.
01-20-2014, 08:17 PM
On our Rockwood the motor can be accessed from the top and they provided a flexible bit driver for a drill that can manually turn the motor & thus the slide in and out. I know this doesn't solve the motor issue but if it had to moved that is how you can do it.
Mark & Barb
2013 8289WS Platinum Pkg
2008 F350 King Ranch CC 6.4
2013 nights camped 35
01-20-2014, 08:27 PM
Good video, anyone know where the controller is on a hyperlite xlr27hfs toyhauler?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
01-20-2014, 09:46 PM
Any suggestions?
If you haven't resolved your problem yet, try calling Lippert Components Customer Support at 574-537-8900...they should be able to help you troubleshoot.
Dave
01-20-2014, 10:06 PM
William
Are these the in wall motors?
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
02-16-2014, 08:24 AM
Gave up and brought to the dealer. He doesn't seam to be having any luck getting to the motors.
DW and i are frustrated with this RV. It has been nothing but trouble since we picked it up. I've had it for two years and I think it spent more time at the dealer for repairs than it did home.
Pulled to trigger on a Passport today.
02-16-2014, 09:33 AM
That sucks! Had to cost big ones to trade just cause of a secret operation. Gotta be a way. Good luck with new one.
02-16-2014, 11:19 AM
when we went to take our unit home after we bought it (brand new) we could not get the slide in, dealer replaced the controller and then the motors went inop, they install higher amp motors then what was installed at the factory, works good now...
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
02-17-2014, 09:33 AM
Does any of video apply to a 2007 32 ft. Forrest River Sandpiper ? OR Does anyone have a suggestion on my living room or dining won't slide in ? The 2 back rooms slid in like they should have but the third room won't do anything. I have been living in the trailer for 4-5 years now so all the slide outs have been out that long. I also need a sleeper sofa and the 2 benches at the dinning table ? The problem is gone and so are her dogs so now I have to replace these items.
02-17-2014, 09:36 AM
Oh yeah one more thing the roll out awning latches broke with the recent snow.I can make a list of used items I need or if the price buy a complete used working awning ?
02-17-2014, 10:39 AM
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
05-05-2014, 10:32 PM
does anyone know where the controller is on a lacrosse 329bht.. looked every where???
05-13-2014, 08:46 AM
Bedroom Slideout
Bederoom slide is not performing well, first time with this problem, two year old coach. When running the slide out, one side seems to go out slower than the other. On retracting, again one side seems slower than rhe other.
Check the controller, no codes and both motors seem to be running when selected. Will try lubricating the motor where the gear makes contact with the tract....
anyone else had this issue???
kickster
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
05-13-2014, 10:18 AM
Schwintek motors
part number for schwintek motor for my crusader 270ret, bedroom slideout..
2011 year model...
05-13-2014, 11:07 AM
2011 year model...
Any chance to get current draws of each motor in operation? That will help weed out excess load/drag compared to motor operation. I'd keep the tracks lightly lubricated full length.
05-14-2014, 08:05 AM
Lippert customer service
Spoke with Lippert Customer Service yesterday, explained to them our problem with our bedroom slide not coming evenly. We were given instructions on how to perform a procedure to get the two slide motors back in sync with one another. We plan to do that this morning as we do not have any fault lights on the control box. Lippert was good at responding to our problem, only hope it works as instructed.
kickster
ps: we are in Wall, SD, moving on to Custer, SD later today...
