Old 08-17-2011, 08:07 AM   #1
Rugged Brown's Avatar
Slide a little noisier than usual
What could be the cause of this. My fifth wheel is only 4 months old and the slide mechanism on the large slide is noticeably noisier lately. When new it would slide very quiet. Now, it is much noisier and a little rougher. What could be the cause and what is the fix. Any help will be appreciated.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
Trying to resist the urge to buy another camper
Rugged Brown is offline   Reply With Quote
Old 08-17-2011, 09:31 AM   #2
Herk7769's Avatar
I would try lubricating the rack and pinion with a good quality dry lube spray.
If that fails you could be out of rig, but you would notice that I am sure.
Lou and Laura - Shopping for a Camping Buddy
2008 GMC Sierra 30000HD Crewcab SB Allison Duramax
HAM CALLSIGN - KC3FFW
Old 08-17-2011, 10:55 AM   #3
Boyd's Avatar
If Herk's lube fix doesn't quiet things down, you might want to check and make sure the slide motor bolts/nuts are tight.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
