Old 06-09-2010, 10:17 PM   #1
slide adjustment
Greetings Campers (first and long time) I'm trying to get advice on a slide adjustment. When I let my slide out.... the trim below the dinette drags the floor. If I push gently on the top of the carriage..... it clears. How do you adjust the slide on this unit???? 2005 Cherokee lite A+ (by the way Bdeuce, if you're out there would you please respond as well if you have had this issue. Thanks
cthelite is offline   Reply With Quote
Old 06-10-2010, 05:39 AM   #2
cardinal4fun's Avatar
You might try this link
http://www.lci1.com/OwnersManuals/Sl...ideout-Web.pdf
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
