Old 09-12-2014, 09:49 AM   #1
jkr1212's Avatar
slide adjustment
I have a 2014 vlite 30wrltsa, one of my slides is out of adj, the front of the slide does not seal up to wall inside the camper about 1/2 inch, and when retracted same front side actually sticks out as well, i looked on you tube and cant find what im looking for, only thing i saw was bringing the slide in adjustment stop, which there is only 1 on that slide and its in the middle, so this adj will not work to bring in the front side of the slide only, as well fix why the slide will not go out all way in front as well. i do not have capability to bring it in for MF warranty so rather do it myself, any suggestions?
jkr1212 is offline   Reply With Quote
Old 09-15-2014, 08:43 AM   #2
Donnieburnett2's Avatar
slide adjustment
Hello! I'm new to the forum and a new owner of XLR 415AMP. I have owned a 5er before. This one has something wrong with living room side. It will go out just fine but it tilts very bad as it starts in. It will get stuck if I don't take my hand and pull it in on one side. Is this normal ?
Donnieburnett2 is offline   Reply With Quote
Old 09-30-2014, 11:44 AM   #3
Stevecooksey
Send a message via Yahoo to Stevecooksey
I have a2014 heritage glen lite fifth wheel my living room slide out did not seal on top inside when out I adjusted the two jack bolts so it would seal inside but when ran in the top outside doesn't seal what other adjustment is there to cure this problem
Stevecooksey is offline   Reply With Quote
slide
