Old 12-02-2015, 04:39 PM   #1
dashonthedash's Avatar
Slide "bangs" when brought in
I have a 2011 Georgetown 280DS. The slides work fine but, when I bring the living room slide in, I get a "bang" when it is all the way in. It almost sounds like the slide isn't stopping correctly, and it is hitting something at the end of its transit. Anyone know what could be causing this problem?
Gary Shapiro, 2011 Georgetown 29' Class A
Dash, Molly & Lily - now at the Bridge and forever in my heart
Shadow - 4-year-old Greyhound
Hannah - 1 1/2-year-old GSD rescue
dashonthedash is offline   Reply With Quote
Old 12-02-2015, 05:05 PM   #2
northstar1960's Avatar
not with out more info
northstar1960 is offline   Reply With Quote
Old 12-03-2015, 07:11 AM   #3
It's a Lippert hydraulic slide with cables on either side. Does that help?
Old 12-03-2015, 07:20 AM   #4
Fulltime in our Berkshire
KennyGolub's Avatar
I had the same problem with my Berkshire. FR fixed it at Goshen by adjusting the cables. Seems mine were loose.
Ken
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 12-03-2015, 12:40 PM   #5
My 2011 Georgetown 327DS had the same problem once, when closing the street side (large) slide. It occurred when I didn't have the RV completely level and disappeared when I levelled the unit. I believe it was the cable anchor on the slide banging into the frame, caused by the slide being a little cockeyed because the RV hadn't been levelled.
Phil
pmsherman is offline   Reply With Quote
Old 12-03-2015, 01:24 PM   #6
Thanks, pmsherman, that could very well be the problem. My RV isn't level while in storage. I could try to level it and try the slide then.
Old 12-03-2015, 04:29 PM   #7
Activate Slide Only When Level
My big front slide makes noises and drags when my Georgetown is not level. So I always level it before doing the slide. Both slides do make noises though but it's more of a "popping" sound. during transit and then a banging sound at the end. I try to release the button as soon as it hits bottom.
hikerjohn7 is offline   Reply With Quote
Old 12-03-2015, 05:52 PM   #8
Are you sure it's not the awning over the top catching? My Hurricane has been doing it since I purchased it and hopefully they will fix it next week. The awning seems to drag and then snap after so much has been slacking. Before I actually saw it I thought some board was cracking. After I've watched it from outside I have identified that it was the awning. Not sure about how your make and model works but can't hurt to check it out. Just saying.
damone0397 is offline   Reply With Quote
Old 12-03-2015, 06:21 PM   #9
You're right, I can't eliminate the awning. I'll have to ask someone to watch it while I bring the slide in. Thanks.
slide
