Old 04-13-2016, 07:31 PM   #1
Slide carpet wet
I have a 2015 coachman freedoms express Liberty edition. After a heavy rain I keep finding the carpet at the front corner of the slide is wet and small puddles of water are in front of it. I can't seem to find where the water is coming in from any ideas?
Bsmallwood811 is offline   Reply With Quote
Old 04-13-2016, 07:43 PM   #2
crunchman12001's Avatar
If you take a close up picture of the exterior of the extended slide seals, we can tell you where it is leaking. The leaks typically come from where the horizontal and vertical seal meet in the corner or improper slide adustment. Also post a full pic of the slide on the side that leaks.
2015 F-250 FX4
Old 04-14-2016, 06:23 PM   #3
Name:   ImageUploadedByForest River Forums1460676145.725866.jpg
Name:   ImageUploadedByForest River Forums1460676157.851497.jpg
Name:   ImageUploadedByForest River Forums1460676175.043806.jpg
Name:   ImageUploadedByForest River Forums1460676184.998132.jpg
Name:   ImageUploadedByForest River Forums1460676200.507108.jpg
I hope these help show what I am talking about thank you for your help
Old 04-14-2016, 06:24 PM   #4
Name:   ImageUploadedByForest River Forums1460676253.936732.jpg
Old 04-14-2016, 06:28 PM   #5
MarkyB's Avatar
Check here...
In Mine the carpet was wet on the front of the slide. Caulked this joint and seems to be dry now.
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
Nights Camped in 2017 : 20
MarkyB is offline   Reply With Quote
Old 04-14-2016, 06:35 PM   #6
It sure is hard to see those seals in the shadows. Can you post another set with the sun shining on the same side. The one pic on top of the open slide is critical.
Another critical question is does it only happen when the slide is open, when the slide is closed or both? Post pics of the slide in the position you suspect the leaks.
Sorry for the retakes, trying to get a look at 'er.
2015 F-250 FX4
Old 04-14-2016, 06:45 PM   #7
Crunchman no worries on the retakes I will grab them tomorrow as it is in a storage it only seems to be happening when the slide is closed. We just had rain this week and the slide was closed and I had water. We are expecting more rain tomorrow and this weekend so I have left the slid open and dried the carpet so I can confirm if this is the case. Thanks everyone for your help!
Old 04-14-2016, 07:21 PM   #8
Well, if it seems to only happen when the slide is closed that makes it much easier. Most trailers now days have a 2 part slide seal. You have an interior and exterior "wiper or squeegee" seal that wipes the slide when it comes in. The wiper seal also helps with air infiltraion, in or out.This seal has a track that fits an interior and exterior "D" seal. The D seal is what keeps the water out. The most common problem is the slide is out of adjustment and does not compress the D seal enough between the slide edge and the trailer wall. If you compound the slide just a bit out of adjustment with a horizontal and vertical D seal that is not cut right in the top corner, you get leaks.
Sorry if that sounds confusing, that is why the good pics are important.
2015 F-250 FX4
Old 04-18-2016, 04:09 PM   #9
Ok after a day of rain plus me with the water hose I have found where the water is coming in and it is no where near where I thought. It is actually coming in through the refrigerator compressor cover. I found the bird underneath the refrigerator was wet so after taking some of the boards and metal brackets off from the bottom of the refrigerator I noticed you could see daylight and traced it to the bottom of the compressor cover Click image for larger version
Name:	ImageUploadedByForest River Forums1461013639.951871.jpg
The second picture is taken between the gap at the bottom of the refrigerator looking towards the back wall Click image for larger version
Name:	ImageUploadedByForest River Forums1461013693.130371.jpg
How do I keep water out of here? Is there supposed to be a rubber gromet of sum sort the third picture is of the outside of the camper with the compressor cover removed Click image for larger version
Name:	ImageUploadedByForest River Forums1461013759.283481.jpg
ID:	105359 any help is appreciated
Old 04-18-2016, 07:04 PM   #10
Wow, never saw that one coming. Good job on finding that one, this is a first for me in that location. The second picture, is that from the interior? Where does that gap come through into the exterior refer hatch on picture three?
2015 F-250 FX4
slide
