Old 04-14-2019, 12:10 PM   #1
Slide does not work
After uncovering my 2003 flagstaff to get ready for the season, I find the slide not working. I went and banged the motor, thinking it may have been frozen but NG.
Havenít been able to find a fuse and canít get to my manual. Any suggestions ?
Dannyboypm is offline   Reply With Quote
Old 04-14-2019, 12:14 PM   #2
Flybob's Avatar
Are you sure Battery is good? Plugged in?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-14-2019, 12:20 PM   #3
bikendan's Avatar
Manual will NOT have any information to help with this issue, as it's generic.
The slide out usually has its own 30 amp fuse, tucked up along the frame, near the slideout.
Equalizer WDH
Old 04-14-2019, 02:40 PM   #4
DaveAlb
I am having the same problem with my 2018 Hemisphere Hyperlite 23RBHL. Checked all breakers and fuses inside and all are OK. Canít find any fuses or breakers under the camper. Worked ok for 2 weeks, and then just stopped.
DaveAlb is offline   Reply With Quote
Old 04-14-2019, 06:38 PM   #5
DaveAlb
Just a note, the slide out switch has been acting up the last week or so.
Old 04-15-2019, 02:21 PM   #6
Dave in Florida
I have a 2016 Leprechaun, and had the same problem. Knew it had to be a fuse because LPG detector also was not working. I called Coachmen. After 2 suggestions where to look for the 5 amp fuses from them, I ended up stumbling upon them on my own. Sounds like they put them wherever they feel like that day. Good Luck.
leblancdave is offline   Reply With Quote
Old 04-15-2019, 03:40 PM   #7
Boots49's Avatar
Send a message via Skype™ to Boots49
There should be a mini circuit breaker near the battery that has to be manually reset. You will have one red wire going to a block & one coming out, on that block you will see a small black button, that you push in. This is the reset button. be careful where you are touching, remember there is voltage there. Hope this helps.
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 04-15-2019, 03:44 PM   #8
Boots49's Avatar
Here is the picture I was trying to add to my earlier post / reply.
Name:	Mini Circuit Breaker copy.jpg
Al & Susanne
Aka: Puss 'n Boots
Old 04-15-2019, 04:03 PM   #9
cavie's Avatar
resettable fuses for slides and battery are under the tongue within 3 or 4 feet of the battery.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-15-2019, 06:23 PM   #10
DaveAlb
Thanks. Found it but with no button or apparent way to reset it. Measured dc voltage to ground from each breaker terminal and got 13.71 v. Thinking that breaker being tripped is not the problem.
slide
