Old 10-17-2016, 11:58 AM   #11
Well, l'm pretty sure the fuse isn't blowing due to binding since I just tore off a cabinet door sliding it out!!!
Two holes poked in the wall. I can't believe this! Think I can get matching wall covering from FR? I was outside with the slide remote making sure I didn't run the slide into a tree.
ID:	123236   Click image for larger version
ID:	123237   Click image for larger version
Pam & John in WI
PamJohnZephyr is offline   Reply With Quote
Old 10-17-2016, 12:01 PM   #12
Left Coast
The latches on my drawers and cabinets are adjustable for tension...check yours, as I had one door that dis that...
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 10-17-2016, 12:03 PM   #13
Left Coast
That door can be fixed....cab shop with pocket hole fixture...
Old 10-17-2016, 12:04 PM   #14
Left Coast
Find a moulding to cover wall to cabinet
Old 10-17-2016, 01:12 PM   #15
I'm not sure that binding doesn't provide more resistance than those cabinet doors.
2012 Forest River 28BH Patriot Edition
2011 Ram 2500 Quad Cab Cummins
Mudinyeri is offline   Reply With Quote
Old 10-17-2016, 01:32 PM   #16
Like the moulding idea, Bob. Thanks. Can you explain cab shop with pocket hole fixture?
Pam & John in WI
Old 10-17-2016, 01:51 PM   #17
Left Coast
Sure...a pocket hole, using a fixture, is drilled with a special bit, to a set distance determined by the wood thickness, on the backside of door outer frame work, called styles and sills, and a special screw is used ....most modern cabs are put together this way....I'll post a pic.....If you'd like to do your repair, HD or Lowe's , have an inexpensive alum jig with instructions....
Old 10-17-2016, 01:55 PM   #18
Left Coast
ID:	123248Click image for larger version
ID:	123249Click image for larger version
ID:	123250Click image for larger version
Old 10-17-2016, 02:17 PM   #19
Left Coast
One more thing...if you find a moulding that is a little fancy, using a pin nailer, you'll never see the pins (fine finish nails) installed at an angle verses straight in
Old 10-18-2016, 10:27 AM   #20
Hot glue gun?
Pam & John in WI
fuse, slide
