Old 09-08-2016, 10:04 AM   #1
Slide has no manual operation for in/out. ???
Hi,
When I bought my 2014 Wildwood Rkss, i was told it didn't have a manual way to extend or retract the slide. Anybody know how I would handle that in a pinch as if it was stuck in the out position with say a bad motor?
Any Ideas?
Jugadorone is offline   Reply With Quote
Old 09-08-2016, 10:08 AM   #2
RSchleder's Avatar
It would depend on the "type" of slide mechanism you are talking about. Post the type of slide system you have and I'm sure you'll get some input.
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 09-08-2016, 10:11 AM   #3
ilmor's Avatar
If its a Schwintek, for example, you disconnect the motors and then push it in or out.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 09-08-2016, 10:12 AM   #4
BTW it is an Electric Slide, I am not sure of the make, it doesnt say in our owners manuel. Doesn't really give a lot of info.
Old 09-08-2016, 11:10 AM   #5
Fulltime family RVer
Does it have top and bottom rails on the side of the slide box that look like these:
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 09-08-2016, 11:20 AM   #6
I'm not home right now to check, but that doesn't look familiar.
Old 09-08-2016, 11:21 AM   #7
Witch Doctor's Avatar
Hi,
Any Ideas?
I can't say for sure but most wildwoods have the LCI slide that runs on a sprocket. If you look underneath and see a tooth bar that is what you have, if it is an LCI then you will see a whole on each slide that a crank fits in and you can bring it in or out. If it is not what was shown you have an accuslide, then you should have got a 12" extension that fits on the motor end and use your drill to do it. We need to know what slide you have first, then someone can really help you....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-08-2016, 11:39 AM   #8
Thanks, The LCI/ Tooth bar sounds more like what i have.
I will check it out.
Old 09-08-2016, 11:49 AM   #9
Head Rambler
Do you have the 29RKSS or the 27RKSS?
Not that it matters, I'm just curious.
You have the LCI electric thru-frame slide mechanism.
Here is a copy of the LCI Electric Thru-frame Slide Manual. The manual operation is on pages 16 & 17.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Bama Rambler is online now   Reply With Quote
slide, manual
