Old 05-30-2013, 04:27 PM   #1
Send a message via AIM to jk31668
slide info. needed
i have a 2010 3100 ss sunseeker. i see lots of posts on slide maint. and the manual way to crank it open/closed if the motor fails. i have looked from the outside and under the slide but cannot see anything. where should i be looking?
2010 sunseeker 3100ss
jk31668 is offline   Reply With Quote
Old 06-03-2013, 12:40 PM   #2
Dallas Texas
TexasBBQ's Avatar
Look inside storage cabinet or under the coach. If all else fails call the dealer.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 06-03-2013, 06:53 PM   #3
annamarie's Avatar
On the corner bottom of the slide you should see a small round hole. This is wear you manually put the arm crank through and open/close your slide. If I have time later I'll try and send you a picture. Or, Herk might have one, he is very knowledgable about everything, and has so many photos to show.
David & Annamarie(Fatty & Harley)
2011 Rockwood windjammer(3065)
annamarie is offline   Reply With Quote
Old 06-04-2013, 04:25 PM   #4
ok, so what is a slide arm crank and where do i get one? thanx
Old 06-06-2013, 07:06 AM   #5
annamarie's Avatar
It should have come with the tt. Look under your bed or cabinets. It's about 3' or so.
