Old 04-01-2016, 06:19 PM   #1
Williamson5's Avatar
Slide leak on NEW TT
We just brought our brand new cruise lite 283qbxl last Saturday. Last night we got our first rain. Now there is a puddle in the middle of the hall going into the bunks in the back, right where the track stops when pulled in. The slide was in the whole time it was raining! How frustrating! I think it's coming in where the seal is notched for the track. Somebody put an extra notch in it, looks odd to me.Click image for larger version
Name:	ImageUploadedByForest River Forums1459552787.916091.jpg
2010 Ford Expedition EL Limited
2016 Salem Cruise Lite 282QBXL
Williamson5 is offline   Reply With Quote
Old 04-01-2016, 06:21 PM   #2
This side doesn't leakClick image for larger version
Name:	ImageUploadedByForest River Forums1459552884.545103.jpg
Old 04-01-2016, 06:30 PM   #3
crunchman12001's Avatar
Question? Are these pictures of the interior sweep seal? If so, I would look outside at the side that leaks to make sure the trailer D seal is in contact with the closed slide. The slide might need adjusted to contact that exterior D seal which actually stops water infiltration. The sweep seals "squeege" water off the slide walls when retracted and help with air and water infiltration when extended.
Can you post pics of the exterior with the slide closed on the side that is leaking?
Sorry to hear you are having issues with your brand new unit.
crunchman
2015 F-250 FX4
Old 04-01-2016, 06:33 PM   #4
davidjb's Avatar
Was the trailer level?
davidjb is offline   Reply With Quote
Old 04-01-2016, 06:39 PM   #5
Yes it's level and those pics where outside with the slide out. These are outside with slide in. This is all new to me. First TT let alone a slide. LolClick image for larger version
Name:	ImageUploadedByForest River Forums1459553929.827148.jpg
Old 04-01-2016, 06:42 PM   #6
IMO, level should not be a factor if the D seal is properly compressed with slide closed. If this was a leak with the slide open, the camper level could be an issue if it was extreme?
2015 F-250 FX4
Old 04-01-2016, 06:50 PM   #7
Picture tells a thousand words. It looks like the side vertical D seal is interfering with the top horizontal D seal. The top needs to be above the side seal. The slide does look like it is good on adjustment, just need to get that corner seal issue tightened up.
Opinions???
crunchman
2015 F-250 FX4
Old 04-02-2016, 03:30 PM   #8
Carknocker Family
Ida Ratherbe Camping's Avatar
Top seal does look to be wadded or bunched up. Side out topper will fix it right up. But seriously, take it back for some adjustments. Or do it yourself and save the hassle.
Ida Ratherbe Camping is offline   Reply With Quote
Old 04-02-2016, 03:35 PM   #9
If I was closer to the dealer I bought It from I would just take it back but if not to difficult I would like to adjust myself. How do I go about adjusting it, to snug it up a little?
Old 04-02-2016, 03:42 PM   #10
Carknocker Family
Open your side up, get ya a ladder and look at the seals. Maybe one just cut a little long or no installed " square ". Just take a look at it open and see what you see. If not sure, pics may help us see what you looking at.
leak, slide
