Old 08-09-2015, 08:22 PM   #1
Slide Lock causes slide-top molding to bow outward: fix
My 2014 Rockwood MiniLite 2109S came with a slide lock to be placed between the TT side wall and the top of the slide. This should prevent the slide from rolling out if the clutch on the electric slide motor should ever release for some reason. Anyway, the problem is that if I crank it out enough so that the pressure is sufficient to keep it in place while on the road, the molding strip at the top of the slide (where one end of the lock is resting) starts to bow outward and separate from the rest of the slide. If I use a lesser amount of pressure (don't crank it out so far), it invariably falls out before I reach my destination, making it useless.
However, I think I've fixed this. I went to the hardware store and got a 4-foot piece of aluminum angle iron, 1/16th inch thick and each of the sides are 1-1/2 inches wide. I glued this in place on the inside of the slide-top molding using construction adhesive. Now the end of the slide lock rests on the angle iron, which can withstand the pressure much better as well as distributing it over a larger area. I can crank out the slide lock without the top of the slide separating. Seems to be working well so far.
2018 Grand Design Imagine 2600RB
2017 Ford f150 XL Supercab 4x2, 3.5L Ecoboost, Max Tow Package, 3.55 Rear Axle, air bags
Equal-i-zer 1000/10,000# Hitch
Mark Ulmer is offline   Reply With Quote
Old 11-24-2016, 07:43 PM   #2
How's that working? I am having same problem
GT383 is offline   Reply With Quote
Old 11-25-2016, 11:50 AM   #3
It's been there over a year and still working great.
mold, slide
