06-01-2017, 01:03 PM
slide maintenance
what is recommended for rubber slide seal maintenance.
This is for the closet slide on 2604 ws...( if the would make any difference )
Also the first 3 inches of rubber tube under topper on the living area slide is
off the track. Any advise!
Any other slide hints appreciated...first unit with slides
06-02-2017, 01:25 AM
The best thing you can do for slide seals are to make sure they are clean, and free of debris such as leaves, twigs, etc.
As far as the rubber tube, I'm assuming that is a d bulb seal. The seal has a runner on each end that goes into a plastic track attached to the unit. You can stretch the seal to get the runners back into the track.
06-02-2017, 01:36 AM
For the rubber seal, you need to spay them with slide out at CW or areo space 303 atleast twice a year or they will dry out. Can't say on the rubber tube without seeing a picture. Also some people use baby powder, but I don't know how well it works.
Coachmen M/H
Concord
2018 / 300 DSC
06-02-2017, 07:38 AM
Thanks,
products to clean rubber?
does anyone use something other than soap and water?
Is there anything 'not' to use on rubber?
Is there a tool to assist in getting tube back on track?
toppers? should I treat with something to protect the surface?
Thanks for advise.
06-02-2017, 04:34 PM
Thanks,
Thanks for advise.
Do not use a silicone base item it will ruin your rubber seal.
Coachmen M/H
Concord
2018 / 300 DSC
06-03-2017, 12:28 AM
Thanks,
Thanks for advise.
Soap and water is the safest way to clean the seals. Do not use any oil or alcohol based solvents to clean or treat seals. The easiest way is to slide the seal down the track until you are past the point where it is off the track, then slide it back. Soap and water to clean the toppers, I do not know of any treatment for toppers... maybe someone else can weigh in on that.
I looked online for a good 45 minutes, and I only found that silicone lubricant is recommended for rubber seals, not bad. Do you have a link to a product description or an article that says otherwise? Because if you do I need to stop recommending it
06-03-2017, 07:30 AM
If you go to the Mequiars on line site it will tell you that it will attract dirt and has no uv protection for rubber. Both products I recommended, will not collect dirt or dry out the seals, also best for UV protection the sun is a killer for rubber.
Coachmen M/H
Concord
2018 / 300 DSC
06-03-2017, 07:39 AM
Also in my opinion aerospace# 303 is the best UV protection, also great for your decals, if you also go to the protect all site, they have a foam non wipe seal protector along with a dry, I wouldn't put silicone on my tires why then put it on your seals, it will dry them out
Coachmen M/H
Concord
2018 / 300 DSC
06-03-2017, 08:09 AM
Coachmen M/H
Concord
2018 / 300 DSC
