Old 04-21-2018, 11:09 PM   #1
Keithe's Avatar
Send a message via AIM to Keithe Send a message via MSN to Keithe Send a message via Yahoo to Keithe
Slide making noises
We have a Forester 2401S which we took out for the first time this year. We were extending the slide and just as it got fully extended and dropped into place, it made a loud bang. This is the first time we've ever heard this noise. I checked under the RV and found a piece of metal that looked like it may have sheared off, see picture below. I'm not sure if it came off our RV or was laying on the ground when we arrived but I checked under the RV but couldn't find anything that looked out of place. The slide fully extends and retracts as it should without a problem but now makes that same loud bang each time it fully extends. Has anyone else seen or heard of this problem? I'm thinking I may need to take it to a local repair shop to have it checked out.
2017 Forester MBS 2401S
Keithe is offline   Reply With Quote
Old 04-21-2018, 11:49 PM   #2
Gut feeling tells me that is a slide stop that came off when the one screw/bolt snapped. Check your slide manual or find your slide on line for pictures/diagrams of the slide mechanism. Good luck.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 04-22-2018, 08:02 AM   #3
What kind of slide is this? My last camper had an issue with a lippert slide where the hole in the frame was cut too big. The stop cup was being pulled through the frame making a loud bang when the slide started to extend or was almost fully retracted.thst caused problems with other parts. I had to make some brackets to keep the cup from going through the frame. I don't have pictures of the final repair. Click image for larger version
ID:	169169Click image for larger version
____________________
2017 Silverado 3500 Z71 CC / L5P Duramax/Allison
2018 Grand Design Reflection 311 BHS
2015 Coachmen Apex 259BHSS 50th Anniversary (sold)
rjc1024 is offline   Reply With Quote
Old 04-22-2018, 06:39 PM   #4
Keithe's Avatar
My understanding is that the 2401S has the Lippert above floor slide. This slide does not go through the frame.
Old 04-27-2018, 06:38 PM   #5
Keithe's Avatar
I found out that it was a slide stop that failed. I took my RV to Waterdog RV which is a local RV sales and service center and they fixed it for $165.00.
noise, slide
