Old 03-23-2013, 01:56 PM   #1
Slide Motor
I have a 2005 Flagstaff 831BHSS. The main living room slide out is working fine. The bedroom slide will not slide out. Motor makes no noise. Camper is plugged into shore power and battery on tongue is fine. I charged it to make sure. I found one black fuse holder very close to the tongue and it is fine. I can see the motor on the main slide but don't see the motor on the bunk house slide. Any advice on finding any other fuses and do I just need to remove under belly covering or cut a access hole to find the bunk house slide?
lottknox1 is offline   Reply With Quote
Old 03-26-2013, 10:12 PM   #2
PhotoMaster's Avatar
I'm new here and not familiar with the Flagstaff or the fuse locations, but when you find the fuse, I do have a suggestion. My new 2013 Roo 23SS had the same issue with the slide out and it was a blown fuse under the TT. When the repairman fixed the issue, he replaced it with a self resetting circuit breaker (resets after a short time when tripped). Haven't had an issue since. All the best.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 03-27-2013, 06:48 AM   #3
jtstromsburg's Avatar
Dumb question, but have you checked the fuse panel? In my old tt, there was a fuse in the panel for the slide.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 03-27-2013, 07:08 AM   #4
TURBS's Avatar
X2
And also x2 on the auto resetting breaker.
One looks like this.
Old 03-27-2013, 07:10 AM   #5
TURBS's Avatar
Its possible you may have one of these and need to manually reset it.
See the black button?
Turbs
Old 03-27-2013, 12:24 PM   #6
I have checked the main fuse panel and checked all the 12v fuses. I will look and see if I have a resettable fuse like the one in the pic under the unit. I have a enclosed underbelly so I can only see so much.
Old 03-27-2013, 12:30 PM   #7
TURBS's Avatar
IT is possible that its under the skinned under belly but "normally" not.
when you crawl under your unit look for a houshold junction box and you may even have to open it to see if theres one in there.
turbs
Old 04-02-2013, 05:27 PM   #8
F1100 Turbo Thanks!!! Problem fixed. I did have to cut access to see in the underbelly but saw where the house junction box was. Cut another access opened up the house junction but no resettable fuses. Then shined a flashlight up there and saw 3 of the resettable fuses you pictured above mounted to the frame above the junction box. The first one I tried reset. Hooked the battery back up and the slide worked!! Thanks again for your help. I would have never figured that out and would have ended up spending a bunch of money at the shop. You ever get near the Carolinas and need anything just let me know.
Old 04-02-2013, 05:39 PM   #9
TURBS's Avatar
Dually noted!
Most often they cut an access hole then cover it back up with a bigger pice of underbelly skin.....
Glad you got it!
Old 04-02-2013, 05:41 PM   #10
TURBS's Avatar
FYI I would consider replacing those circuit breakers with auto restting ones of the same amperage.
That way if one does it again you don't have to crawl underneath to reset.
Turbs
Old 04-02-2013, 05:46 PM   #11
Turbs
Definitely a great idea. Then you can patch the underbelly and not worry about cutting it again.
2014 FR3 30DS
Old 06-25-2013, 01:14 PM   #12
I called the tech that replaced the bad fuse and he used a 30A, self resetting breaker. I hope this helps.
2014 FR3 30DS
