Old 06-29-2016, 05:14 PM   #1
Slide motor needs replacement
My schwintek slide motor needs replacement and the slide is closed. One motor works but one is not moving. I know it's not the controller or cable. I can't push the dead side open to access the screw. Thought about drilling a hole in the exterior trim to get access to the screw. Any suggestions. It's a small slide.
uralman is online now   Reply With Quote
Old 06-29-2016, 05:36 PM   #2
Have you tried the electronic override? There are no errors on the controller?
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-29-2016, 06:02 PM   #3
I tried the override but motor 1 would not work.
Old 06-29-2016, 06:04 PM   #4
The error message is 8 on motor 1. Wire short. But I keep a spare cable I ran the new cable and still no go.
Old 06-29-2016, 06:34 PM   #5
Had same problem last year. me and my bro were able to move it out about a foot by pushing very hard ! we are big guys so maybe that helped . Had to remove the power to the motors first to let off brakes
Ive been told no way cant be done ..... worked for us just saying
1999 dodge 2500 Diesel 4x4
2016 Wildcat Maxx
282rkx
aupainter is offline   Reply With Quote
Old 07-01-2016, 04:57 AM   #6
DouglasReid's Avatar
a possible option
after removing power to release the brake, would it be possible to use a bottle jack and a purpose cut 2x4 to push on each of the steel slide members horizontally to push it out enough to access the screw?
2012 Wildcat Sterling 32RL, Maxxis 8008s Load rating E, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 07-02-2016, 12:33 PM   #7
May have to either try to remove the exterior slide fascia or hire the Packer offensive line to push.
Old 07-04-2016, 12:39 PM   #8
I disconnected power to the bad motor and pushed out easier than I thought. Didn't need the Packers after all. Changed the motor and back working again. One of the wires broke off the motor circuit board.
Old 07-04-2016, 06:06 PM   #9
Head Rambler
Thanks for coming back and letting us know what you did to get it fixed. Especially the part about removing the power and being able to move the slide.
Gotta go campin!
replacement, slide
