Old 05-12-2013, 02:31 PM   #1
slide needs adjustments
Hi all,
I own a 2012 salem hemisphere 26rls .It has a super(i think some call it king slide) slide but i cant find the maunfacture or what type it is anywhere in my trailer or the paperwork that came with it...Is it a for example a flush floor slide,above floor and so on and so on. Im guessing its a lippert slide and i have visited the website to try and download a manual but there are a "million" types of slides.HELP The slide must of moved during travel and it needs to be lifted on one end as the seal is not touching on the top corner of opposite end that needs to be risen.
newfiecamper is offline   Reply With Quote
Old 05-19-2013, 06:05 PM   #2
It should be an electric lippert slide out on a Salem travel trailer. There is a Lippert slide out manual (24 pages) on this website that I recently downloaded about 2 weeks ago, for your unit. My Flagstaff V lite has the same large slide out. The illustrations are very good on this printout. If you are still cautious about this, see your dealer service dept. They can perform the required adjustments needed. Randy
Old 05-20-2013, 06:14 PM   #3
Hi mine is a schwintek in wall slide system. Rv tech told me that there are no adjustments for this type of slide. He told me to run it in and out several times and it should be ok so I did just that and it did go back to normal but I moved the trailer again and now it's off again. Maybe I don't have the trailer level enough but I try and get it the best I can.
