Old 08-05-2012, 05:06 PM   #1
mike54's Avatar
Slide No Longer Working
well this sucks one week until we leave for the rally & just got back from a trip today went to bring the bedroom slide out and it just clicks should I try to get it fixed before we leave or take it the way it is and let forest river fix it? it's just over a yr old
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 08-05-2012, 05:12 PM   #2
Iggy's Avatar
Charge your battery and try again. Relay clicking usually means low voltage. Good luck
2012 Georgetown XL - 378TS 73K miles
Ret. USAF Vietnam, '68 - '89
Old 08-05-2012, 05:33 PM   #3
BOBFIDY's Avatar
.....Or try plugging the trailer into shower power or into the truck plug in.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 08-05-2012, 06:36 PM   #4
mike54's Avatar
it is plugged in to shore power. it went in at the campground with no problem
Mike & Marsha
Old 08-06-2012, 09:52 AM   #5
Iggy's Avatar
That way you are using the invertors DC power for the slides.
Check the battery with a DC volt meter. A good fully charged battery should be at least 13 volts. And don't be plugged into shore power when checking.
Old 08-06-2012, 10:01 AM   #6
Herk7769's Avatar
Your seals are stuck to the walls. This happens when they are not lubricated with slide seal spray (basically dry silicone spray). It also happens in winter when rain freezes the seals to the walls.
Get a plastic cake spatula, spray it with slide seal or silicone, and pry it carefully around the seals. It should open or close easier after that.
Slide Out Lube & Rubber Seal Conditioner - Product - Camping World
HAM CALLSIGN - KC3FFW
Old 08-06-2012, 10:01 AM   #7
Find the manual override for the slide, give it a few turns, just enough to move it, then try again. Sometimes the seals will stick, and the motor may not be strong enough, or the clutch is week, which I think is your clicking, not a relay.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-06-2012, 10:21 AM   #8
mike54's Avatar
found the over ride but it's a shaft with a pin going thru it and I can't find a tool here to fit it
Mike & Marsha
Old 08-06-2012, 10:23 AM   #9
Herk7769's Avatar
It is your stabilizer or "landing gear" manual crank. In my rig (opposing slides) the stub shaft works the opposite slide.
Name:	9 Nov 2009 002.jpg
ID:	17571   Click image for larger version
Name:	9 Nov 2009 003.jpg
Old 08-06-2012, 10:24 AM   #10
Usually a 3/4 inch nut, so a 3/4 inch socket should fit. Same size as scissor jacks on corners. On some models, the same crank handle works both. Just have to find the access hole in the siding.
LadyWindrider
Old 08-06-2012, 10:25 AM   #11
mike54's Avatar
nope tried that there is no slot to fit over the pin
Mike & Marsha
Old 08-06-2012, 10:38 AM   #12
Take a cutoff blade on a grinder and cut the slots. A Dremel works, but takes time and a few blades.
Old 08-06-2012, 10:54 AM   #13
Triguy's Avatar
You can also order replacement handles. Obviously, this is for the future.
Lippert Slide-Out Crank Handle
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
