03-30-2018, 02:05 PM
Slide not sealing after I Goofed!
Help! I didn't have a chair in the right spot when I closed the slides and when the 2 opposing slides came in the recliner in the way pushed the drivers side slide out to where the bottom of the slide in the rear doesn't hit the seal. The front of the slide looks normal. What can I do to fix this, Hopefully an easy fix?
Thanks in advance
2016 Cedar Creek 34RL
2014 Ram 2500 4x4
03-30-2018, 02:17 PM
Insert witty title here
Have you tried manually cranking it?
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
03-30-2018, 02:20 PM
I dont have a manual crank to try
2014 Ram 2500 4x4
03-30-2018, 04:06 PM
I don't know what type of slide you have but on some the motors reset when you put it all the way out again. Here is a link I found as well.
http://www.liveworkdream.com/2015/10...ls-adjustment/
03-30-2018, 04:07 PM
Is it a lippert slide? The tracks are flat, with a wavy looking pattern, kind of like a worm ate it's way thru wood.
Bill and Gail
2016 Sunseeker 3010DS
V10 6 speed transmission
2017 Ford Fiesta toad
03-30-2018, 05:50 PM
Well after looking more closely it looks like the bracket from the slide frame to the arm the piston pushes out bent.
Gee its fun owning an RV! I learned another lesson, and at least it can be fixed
Thanks for the ideas.
2014 Ram 2500 4x4
03-31-2018, 01:52 PM
Im not saying that most if not all of us have made mistakes that cost us money.
But your statement seems to denigrate those of us who enjoy it as a Leisure activity..............
To that I say, Gee it must be fun being You!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-31-2018, 02:36 PM
Sorry about your mistake, no one is perfect and don’t let anyone make you feel that you degraded them. Get it repaired, move on , happy RVing.
03-31-2018, 04:55 PM
Happened to us too!
This happened to us when something was in the way of the two opposing slides coming in, the last slide in got a bent arm, looked just like yours. Thankfully it was on the backside of the RV and we made it home. Costly to get it fixed at the RV dealer somewhere between 250 and 275 if I remember correctly. Bad thing though, a few months later when insurance had to replace the seals on the same slide, it was out of adjustment and so we got charged again, I think it should have been adjusted on the first go round, when they fixed the bent arm. Learned my lesson about running the slides in for sure.
03-31-2018, 06:32 PM
Bene Gesserit Rule
I am pretty sure they all have a manual crank. Might be the wheel lug device. Look for a hole in the side to poke the handle through. If that's there, then look for the handle.
03-31-2018, 06:34 PM
Bene Gesserit Rule
Either a rack-and-pinion or a screw. With the R-P you can manually push the slide in (need big muscles). Not so easy with a screw type system.
03-31-2018, 06:35 PM
Bene Gesserit Rule
Ahhhh, so you are the one in a million who doesn't have problems. Well done.
03-31-2018, 06:58 PM
Nope!
The Schwintek slideouts, which are quite common now, don't have a manual crank.
You disconnect both motors and push it in.
03-31-2018, 10:22 PM
Bene Gesserit Rule
Originally Posted by bikendan
Nope!
Heave Ho the neighbours go.
04-01-2018, 06:41 AM
Please when ypu post your pics rotate them so I don't have to turn my computer on its side to look at it
