Old 02-15-2014, 04:50 AM   #1
Witch Doctor's Avatar
Slide opened on I-10 going 65mph
I strange thing happen to me in my travel yesterday. My bedroom slide opened the whole way as I was traveling down the road. This was my bedroom slide which is up high and is maybe 3' max with a topper (wardrobe slide). This slide is on a 12v motor and pulls a chain across the inside top which pulls 4 cables 2 at the top and 2 at the bottom. I have no idea how this could happened check the 12 volt can find a short. My other 2 slides are the normal rachet type geared. The slide is high enough so I can not see it through my mirrors. The guy next to me got my attention he was behind me until he seen it open. I guess their is a blessing in this. I pulled off the road and closed it. I would say 20 minutes later the traffic just stopped a terrible accident happen 2 or 3 car pile up with having a helicopter take someone away. There was nothing left of the middle car it looked like a beer can that was stomped on. Hope he's or they are okay. But back to the question anybody know why that would happen with my slide? Or what I should look for? Thanks for your help....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 02-15-2014, 06:15 AM   #2
Platokidd's Avatar
Any chance at all that you forgot to close it before you left??
Hopefully someone here has some know how on this... A short would be my guess.
And if you got it close the cables are all good.
Im also wondering if that cable motor lost its holding ability. Can you push the slide out when closed?
Goodluck
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 02-15-2014, 06:49 AM   #3
Goodluck
No it was closed for sure, My last thing I always do is check that all my landing gear is up, antenna is down all hatches and slides closed. Can not find a short unless something happened in the switch which I checked and pulled out and found nothing not even a burnt spade or loose wire, No wires at all touching at the motor which is on top inside the unit very accessible. Thats why I wounder how that can happen?......
Old 02-15-2014, 08:01 AM   #4
Kaadk's Avatar
Did you get a slide lock with it? I found during my research into why I had locks and my buddy didn't that it depended on the slide mechanism. I also read a few stories of guys with 5ers like yours that would get a slide lock for just the one slide, since that slide had a different mechanism than the rest.
There's a lot of debates on the use of locks, but I run with them always, except maybe the short jump from home to storage yard.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 02-15-2014, 08:16 AM   #5
LKicklight's Avatar
Slide Out
We have never had this in either of the RV's, but just in case it ever did, we have always used the safety bars to hold the slides in while on the road. Seems to work pretty well as we have never had that problem, just another step before pulling out, probably takes an extra five minutes to be safe:
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 02-15-2014, 08:25 AM   #6
Dave_Monica's Avatar
Hey Glenn...sorry that you're having problems with the wardrobe slide. It's made by BAL...here's the manual for it... http://norcoind.com/bal/downloads/ac...ion-manual.pdf
There's no reference in the manual for your specific problem I'd suggest you call BAL directly at 574.262.3400
Dave
Old 02-15-2014, 08:26 AM   #7
Herk7769's Avatar
Sounds like your affected slide is a NORCO Accuslide slide out like my wardrobe slide. It also uses a cable system.
The reason these slide outs don't use safety bars is that they need to have motor rotation to move them in OR out. The mechanical advantage is to the motor which must rotate.
That is why the backup slide extension system is a flex drive for a drill.
The only way this could happen is:
1) a short to ground in the open/close switch
2) If they are remote operated someone sat on the control
3) you missed it THIS ONE TIME (happens even to professionals)
Name:	Wardrobe Slideout Motor.jpg
ID:	46285   Click image for larger version
Name:	Flex Drive Tool.jpg
HAM CALLSIGN - KC3FFW
Old 02-15-2014, 09:06 AM   #8
Thought you were going home from Pensacola?
Old 02-15-2014, 09:51 AM   #9
We are going back to Virginia but wanted to take 95 up, Georiga, SC and NC are prepared for bad weather not like Alabama, they don't even own a snow plow or salt and sand trucks. On TV news it showed them dumping a load of sand on an overpass and spreading it by a backhoe bucket. So decided to take 95 up. I'm in Jacksonville FL. now will leave for home in the AM or Monday. I cut a 2x6x17" to fit my slide when it is closed as a brace. It won't open again with that brace and I padded both ends. .............All this and my 2nd year warrenty ran out the 10th of February....Luck of the Irish....
Old 02-15-2014, 10:02 AM   #10
NELA
Weezer's Avatar
Another post that reminds me why I keep coming back to this forum.
I found that flex drive in a drawer in the kitchen of our new 5er. DH and I figured it was something left by a worker on the assembly line.
So now I get to tell him to take it out of his shop tool box and *put it in the camper tool box*.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
slide
