Old 06-10-2019, 05:12 PM   #1
Slide out
I have 2003 Wildwood 38bhds. Opened my slide outs went to close just single click in motor. Checked everything. Has 3 wires coming from motor,blue,green black. Took my jet ski battery hooked up green wire (slide in) and black wire to negative see if motor runs,nothing. Battety new,fuses good. Do I need motor, Guess I do since motor should of ran hooked up to battery. Anyone know where get motor,it is 108amsp32-lb-1hsp Parker oildyne or any suggestions appreciate
kgarnersr is offline   Reply With Quote
Old 06-11-2019, 09:47 AM   #2
SeaDog's Avatar
before you decide the motor is dead check the wiring. Some DC motors use green as ground and blue and black for direction control. It would be worth trying.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-11-2019, 10:29 AM   #3
Slide outs
Thanks seadog. Tried everything. Motor has 3 wires green for slide in,blue for slide out,and black is ground. Just don't know how to test them wires. Can I hook up to battery directly to test motor? Please help
Ken
Old 06-11-2019, 12:47 PM   #4
SeaDog's Avatar
How did you decide which color does what? did you pull the switch on the wall? You can take your multimeter and test the disconnected wires coming from the switch to the motor at the motor using someone else operating the switch and see if you are getting power.
Retired Navy
Old 06-11-2019, 03:13 PM   #5
Slide outs
Seadog- it tells you on one wire is in and other out. I just don't know how to jump it to see if motor bad. Your supposed to be able attach wires to battery somehow to see if motor runs
Old 06-11-2019, 03:29 PM   #6
koller1509's Avatar
Ken
Hook black to negative on battery and touch the green or blue to the positive and see if it moves.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 06-11-2019, 03:30 PM   #7
Iwannacamp's Avatar
I suppose you could put a fuse holder in-line with your test leads as that might prevent any permanent damage.
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 06-11-2019, 03:39 PM   #8
Slide outs
Yes seadog- thanks again. I used my jet ski fully charged tried that and nothing. Used jet ski battery because under cabinet by bed hard to get to. I will try my regular battery,but I think with that little battery should have heard something- nothing. I appreciate your help,wits end here. Motor over $500
Old 06-12-2019, 06:19 AM   #9
SeaDog's Avatar
With the power removed have you tried to manually move the slide to make sure it not binding. If the slide moves fine I think I would remove the motor and then test it with a battery.
Retired Navy
Old 06-12-2019, 08:03 AM   #10
Slide outs
Again thanks seadog- ,when you release pressure on hydraulic you see slide out move. Can you please tell me how to hook up motor to battery to test.
slide, slide out
