Old 09-19-2010, 09:47 PM   #1
Slide out
Having trouble keeping slid out closed while towing. Forest River Sierra 2001 23ft 5th. It has a power gear system. Can anyone help me with this problem
Sapper1
sapper1 is offline   Reply With Quote
Old 09-19-2010, 09:49 PM   #2
milzat's Avatar
Are you using the slide-out lock bars when traveling??
milzat is offline   Reply With Quote
Old 09-19-2010, 09:55 PM   #3
milzat's Avatar
Slide Lock
Old 09-19-2010, 09:56 PM   #4
Slide out
Mike I just bought this 5th wheel and am not aware of any bars to use. I ended up disconnecting the wiring to keep it closed
Old 09-19-2010, 10:03 PM   #5
milzat's Avatar
You're saying the slide does not move out with the wiring disconnected???
This don't sound right.
Old 09-19-2010, 10:11 PM   #6
milzat's Avatar
If this is so, I'd test the voltage at the slide motor while connected to your tow vehicle. You may have a slight voltage applied to the motor. Could be a problem with the slide-out switch.
Old 09-19-2010, 10:11 PM   #7
Slide out
Yes it doesn't move out with wireing disconnected
Old 09-19-2010, 10:19 PM   #8
milzat's Avatar
See my reply above you last post.
Old 09-19-2010, 10:47 PM   #9
Thanks I will check the power source first and buy the lock bars
Sapper1
Old 09-20-2010, 05:30 AM   #10
milzat's Avatar
You may not need the Lock Bars after you figure out the problem. I have never used mine; and many others haven't either.
