Slide out actuator squeaking.
Been hearing a squeaking noise when opening and closing two of my slide outs. The noise is much more when closing then when opening. So I did some reading and thought the problem was that I needed to lube the pinion gear carrier. I did that and it made no difference so I had someone close it while I was underneath and the noise appears to be coming from end (where it is attached to the slide out) of the actuator. Is there a way to lubricate that? My 5ver has the enclosed underbelly and there are access points to the motor drives but the noise is coming from the other end.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
