Old 05-22-2018, 01:33 PM   #1
slide out alignment
We have a 2002 Georgetown. Our bedroom slide has started leaking. We have had all seals replaced. We realized the slide out is out of alignment, it looks like it has shifted from left to right and it not sitting level causing the seals to not sit snug to prevent leaking. We have taken it in to 3 different RV repair shops and no one can figure out how to level it. We have looked and see no where it can be adjusted. Does anyone know who I might be able to contact that would be able to help give us the information we would need to have it fixed.
layoungga is offline   Reply With Quote
Old 05-23-2018, 06:49 AM   #2
SeaDog's Avatar
It might help to get a good answer if you post what type of slide you have or post a pic of the slide extended to we could see the operating system. You description is a little hard to understand when you say not level do you mean out at the top or bottom or is it tilted from one side to the other.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
alignment, slide, slide out
