Old 01-10-2020, 11:48 AM   #1
slide out binding
Where is the slide out motor on a 32ft puma living room. Will not slide out. Lights dim when button is pushed. Also legs will not drop or raise
,no power. How do I realise the motor to the legs. Both fuses on tongue are good, new (2)day old batteries and plugged into AC.
dbhighlander is offline   Reply With Quote
Old 01-10-2020, 12:43 PM   #2
bikendan's Avatar
You need to post the year and model number of Puma. Just saying it's 32ft isn't enough information. Slide motor location varies by floorplan.
Equalizer WDH
Old 01-10-2020, 01:04 PM   #3
Lacey's Spring, AL
formerFR's Avatar
sounds like your batteries are low/dead... otherwise the lights shouldn't 'dim'....
formerFR is online now   Reply With Quote
Old 01-11-2020, 10:56 AM   #4
Slide will not extend.
Sorry. I have a PUMA 32ft, RKTS ,2017. I INSTALLED 2 new 1,000 amp batteries connected the power LINE and the truck.
The outside outlet has no power ,the outlet under the cabinet and the one by the stove have no power. Everything else works and is hot. The living room Will not slide out and when the switch is pressed the lights dim. I need to find the slid motor so I can release it and crank the room out. ALSO the support legs have no power.
HELP. The power CONVERTER and inverter are brand new. I was hit with a power surge and had to replace both. Both fuses on the tongue are good.
Old 01-11-2020, 02:22 PM   #5
bikendan's Avatar
Here is floorplan pic and specs for OP's TT:
https://www.rvusa.com/rv-guide/2017-...32rkts-tr31210
OP, that's why I asked for model number, because your TT is actually almost 37ft long. The number in the model number almost never means actual length.
Equalizer WDH
Old 01-11-2020, 03:27 PM   #6
slide out stuck
I checked the floor plan but did not see anything showing the location of the slid out motor. I also need help on how to manual extend the slide.
Also any suggestions on the ELECTRIC problem.
Old 01-11-2020, 03:39 PM   #7
JUst a WAG
But it sounds like possibly a connection wasn't tight and came loose when the convertor and inverter were replaced.
At least, if it worked before you left on your trip, bounced down the road a few miles and now some things don't work there's a good chance that a loose connection is the issue.
But like I said - just a WAG.
PB&J
2012 Ram Laramie 2500 4x4 CC SB Cummins
2016 Flagstaff 8528RKWS
Patrick (order taker), Barbara (order giver) & Jasper (Dutch Shepherd) aka PB&J
PatrickY is offline   Reply With Quote
Old 01-11-2020, 05:33 PM   #8
Head Rambler
The specifications say that you have "Electric rack and pinion slide mechanisms". That sounds like it's probably the thru-frame slide. If that's the case then the motor will be under the RV between the frame rails.
However, I agree that it sounds like a low voltage situation. It could be caused by a loose connection causing a high amp draw.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
slide, slide out
