Old 03-14-2015, 06:57 PM   #1
Slide out button intermitting anyone else have this problem?
I have a 2010 Sandpiper 345ret and the slide out doesn't really work from the panel. It works intermitting maybe only when sliding it in. I have to use the one by the pump. Is this a common problem, like the switch etc.? If anyone has experienced this I'd appreciate the info. Thanks
cclark746 is offline   Reply With Quote
Old 03-14-2015, 08:56 PM   #2
Dave_Monica's Avatar
I think you're describing a hydraulic slide drive, correct? I have heard of the auto resetting circuit breaker getting weak so the pump starts/stops many times when moving the slides. If it works without starts/stops using the manual overide switch at the pump, that may confirm the issue. Try finding and replacing the auto resetting CB.
Dave
Old 03-14-2015, 09:03 PM   #3
Yes it is hydraulic slide thanks. I will check that out first.
Old 03-23-2015, 04:37 PM   #4
Left Coast
And if you're careful, I would try to jump across the back of switch to test it. Process of elemination (no spell. checker here)
slide, slide out
