Old 02-08-2016, 08:56 AM   #21
Wolverine 1945's Avatar
Originally Posted by Ford Idaho View Post
Got one like this?
Press the little black button.
Our old Flagstaff TT had fuses like this under the tong !!!
Wolverine 1945 is offline   Reply With Quote
Old 02-08-2016, 07:36 PM   #22
Ford Idaho's Avatar
Mine has one mounted to the wall just above the battery box in the front storage compartment it has a red plastic cover over it.
Old 02-14-2016, 03:55 PM   #23
Make sue the connections are good and tight. I just went through the same thing. Tighten both the hot an ground cable that goes to the pump
jerryhowell is offline   Reply With Quote
Old 02-15-2016, 07:12 AM   #24
And clean,,, same with your battery posts !!!
Old 02-15-2016, 07:33 AM   #25
Originally Posted by grumpy0374 View Post
I know you are all talking about trailers, and I'm talking about our Lexi motor home, but I suspect that the systems are similar. That being said, I found a hidden re-set switch in the Battery control Center that supplies power to everything comming from the battery, including the slides.
In the pics of the battery control center you will see the converter breaker listed . It sits just below the 3, 20 amp mini breakers (gold color) that are for the slides. That converter breaker has a small (read VERY small) re-set switch that is almost impossible to see (black switch on a black housing), and if it pops, none of the slides will work.
Just something else to look for.
Grumpy
That one caught me, couldn't see it, finally just stuck my hand in and felt around and found the button.
Ed & Gay
Mini-Schnauzers Dora & Mabel
(Phoebe, in our hearts)
2014 Forester 3051s
2013 Fiat 500 Sport
Workin on my Curmudgeon badge
rapiniii is offline   Reply With Quote
Old 02-15-2016, 08:32 AM   #26
WFD
This post is a good reminder of why you should have a drill with you. Also make sure you have the attachment provided to you that you can put on your drill to bring the slide in. It normally can be found in one of the drawers.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 02-15-2016, 08:59 AM   #27
Don't believe out Sunseeker came with any sockets or attachments ???
Old 02-21-2016, 02:06 PM   #28
mike.t's Avatar
How does a drill work with the motor and what attachments does a person need?
THANKS. Family is stuck with slide out wont retract.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 02-21-2016, 02:12 PM   #29
Ford Idaho's Avatar
Depends on your slide.
Old 02-21-2016, 02:41 PM   #30
mike.t's Avatar
Thanks ford. Fellow camper had a drill and a hex and got them fixed up.
2015 Salem 27RKSS
55' Chevy Bel-Air
slide, slide out
