Old 02-06-2016, 11:53 AM   #1
Slide out failure - need help
Hello,
Camping in Florida in a Flagstaff 8528IKWS 5er and when breaking down to move the bedroom slide is not working.....won't come in.
I have looked at the cable chain mechanism and it "looks" okay. Seems to be getting no power. I checked fuses and breakers and all other electrical seems ok (other two slides)
Can I manually pull it in? How?
Any troubleshooting advice appreciated.
Wdw0528
Darrell & Kathy
2018 Oliver Legacy Elite II
2013 Ford F250 6.7 Diesel
2013 Flagstaff 8528IKWS 5er (Sold)
B&W Companion Slider (Sold)
wdw0528 is offline   Reply With Quote
Old 02-06-2016, 12:35 PM   #2
Oops.....now realize the front power jacks are also not apparently receiving power. All fuses that I know about are ok.
Suggestions?
Darrell & Kathy
Old 02-06-2016, 12:44 PM   #3
Look for something like this.
Hope this works.
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 02-06-2016, 12:46 PM   #4
They are usually in the front compartment,
"Paul & Laurie"
Old 02-06-2016, 12:57 PM   #5
Thanks Paul but don't see anything like that. Only thing I see similar is the battery disconnect.
Darrell & Kathy
Old 02-06-2016, 12:58 PM   #6
Left Coast
When I had the slide problem, I pulled the switch panel and jumpered off another switch, for power, till got home and found the hidden fuse...
Old 02-06-2016, 12:59 PM   #7
I suspect a hidden fuse is my problem too......still looking. Seems to also control front power jack.
Darrell & Kathy
Old 02-06-2016, 01:02 PM   #8
Left Coast
Mine are separate....2 fuses located down behind battery, and 2 behind power dist. center. This 5er doesn't have the resettable type with the button
Old 02-06-2016, 01:03 PM   #9
Ford Idaho's Avatar
Got one like this?
Press the little black button.
Old 02-06-2016, 01:08 PM   #10
Left Coast
Power landing gear switch....needs to be put in a compartment out of the weather.....sometimes just rock'en the switch back and forth will make it work
slide, slide out
