Old 04-21-2018, 06:52 PM   #1
Slide Out Fuse???
I have a 8292 BS Rockwood Ultralight fifth wheel. The slides were working fine. I put one side in the then the other side just stopped. Everything else on the panel works fine. I figuring it's a fuse for them but I can't find it. Does anyone have any ideas where to look? Thanks
Crystalgal2002 is offline   Reply With Quote
Old 05-28-2018, 02:13 PM   #2
Slide
Hi Iím having a similar problem did you find the fuse?
RCS1 is offline   Reply With Quote
Old 05-28-2018, 02:38 PM   #3
Head Rambler
It's usually a reset-able breaker near the battery. They have a small black button on the side that you press in to reset.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 05-28-2018, 02:50 PM   #4
cavie's Avatar
Near the battery. Regular trailers it's under the frame near the battery. 5th wheels are anybody's guess. when I get back north I'm gonna have to look for mine.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-28-2018, 02:53 PM   #5
bikendan's Avatar
Also each slideout should have its own fuse located underneath the slideout.
If the other slideout is working, it's not the resettable circuit breaker.
Equalizer WDH
Old 05-28-2018, 03:04 PM   #6
Yes behind the battery there are 2 stud post that look like they are grounds slide your finger down the side of them they is a reset button there it wont be sticking out far. Hope this helps took us a few weeks to find it
fuse, slide, slide out
