Old 08-21-2013, 10:32 AM   #11
iluvlcy's Avatar
We are still on the original battery that came with trailer do you think it is time to replace? Everything looks ok do not see worn wires or anything.
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 08-21-2013, 11:02 AM   #12
Triguy's Avatar
I think you should test it. It might be time to replace depending on usage, maintenance, battery size and quality. You can do some of the testing yourself, although its often easier to get it load tested locally.
To test it yourself: The most accurate method is measurement of specific gravity and battery voltage. To measure specific gravity buy a hydrometer, to measure voltage use a multimeter. See this battery users guide for help (pages 18-19).
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-21-2013, 11:54 AM   #13
Dave_Monica's Avatar
Fuse blows before that sound when we change fuse and hit the button again it makes the racheting sound but does not move cause it has already made it in before blowing.
I'd recommend that you look at the slide room adjustment, in particular the stop adjustment for the 'In' position. Check out page 11 in the owner's manual... http://lci1.com/images/Flyers/Owners...ideout-web.pdf
Dave
Old 08-21-2013, 12:12 PM   #14
iluvlcy's Avatar
On the battery, on this last trip I started the fridge about a day and a half almost 2 days before we left when we got to the trailer to leave the battery was dead it should last longer than 2 days?
Dave are you suggesting that the slide is hitting too soon?
Thank you both for your help by the way.
Pam & Don
2011 Rockwood 2304s
Old 08-21-2013, 12:20 PM   #15
I'm wondering if the stop can has loosened and isn't coming in contact with the frame when the room is retracted...thinking perhaps the motor continues trying to compress the seals, increase load and blows the fuse with disengaging the drive clutch.
Dave
Old 08-21-2013, 12:38 PM   #16
iluvlcy's Avatar
Thanks we now understand what your saying and will check. Thanks so much Dave that manual was a great help as well.
Pam & Don
2011 Rockwood 2304s
Old 08-21-2013, 01:17 PM   #17
Triguy's Avatar
A new or well-maintained deep-cycle or marine battery will last longer than 2 days. But, a small and older group 24 battery (std equipment in many trailers) could easily be drained in less than a week with enough parasitic draws. It was not just the fridge, but also the CO detector, radio, and anything else with a parasitic draw.
By "dead" I think you mean it was completely discharged. Remember that batteries should never be drained lower than 50% of full charge because that greatly shortens their life. I would guess this battery might be having trouble keeping its charge if this happened too often. Another good reason to test it.
Scott
2012 Shamrock 233S
Old 08-21-2013, 03:11 PM   #18
iluvlcy's Avatar
So if we decide to go ahead and replace battery any tips on what we should look for?
Pam & Don
2011 Rockwood 2304s
Old 08-21-2013, 03:37 PM   #19
Triguy's Avatar
Did you test the battery, yet? Don't want you to spend money if you don't need to.
If you are considering a new battery, first consider your usage/need and then match the size and type of battery to your need.
Do you dry camp (i.e., without 120VAC) often and for how many nights? Barely ever? Just some of the time?
  • If you dry camp often and rely solely on your battery, than get the biggest batteries you can afford that will fit on your trailer.
  • If you rarely camp without A/C, than you have little need for much capacity and a marine group 24 or 27 will do just fine.
  • Somewhere in the middle? Well, that is a balancing act between the most capacity you can afford ($$$) and the group 24 battery ($).
How do you camp? That will point us in the right direction.
Scott
2012 Shamrock 233S
Old 08-21-2013, 03:41 PM   #20
iluvlcy's Avatar
Yeah we are going to have it tested just wanted to be prepared. We always camp with elec and we do not see any dry camping in our future.
Pam & Don
2011 Rockwood 2304s
