Old 01-02-2014, 11:16 AM   #1
Bubbamace's Avatar
Slide out hydraulic line leaking
Hi everyone, I'm new to the forum and have a problem with my 2013 Georgetown XL hydraulic line for the second bedroom rod, part # 248654365. I like to do my own work since the unit is out of warranty, but don't know where to obtain this hydraulic line. I bought my motor home at Mike Thompson's RV in Santa Fe Springs, Ca and have found a lot of literature missing from the book. They have been uncooperative. Does anyone know where to order this hydraulic line? What type of hydraulic fluid does the system use? Is there anything I should know about replacing the hydraulic line. I'm guessing its somewhat like replacing a hydraulic line on a power steering pump? Where would I obtain the literature for the hydraulic system and slide out for this coach. Any part of this answered would sure be helpful. Thank you in advance for any help you can offer.
Bubbamace is offline   Reply With Quote
Old 01-02-2014, 11:40 AM   #2
Remove the line and take it anywhere that they make hyd lines, most napa parts stores do also most farm implement dealers do like your local johndeer . as for hyd oil most of these systems just use atf
lbrunning is offline   Reply With Quote
hydraulic, leak, slide, slide out
