Old 05-04-2014, 10:48 AM   #1
Slide Out Issue
We have a 2014 Flagstaff 25D, we were getting ready to pack up from a campsite. I started to bring the slide in and accidentally hit out momentarily then hit the in but it would not come in like there was no power so we manually cranked it in, the main fuse box was fine is there an additional reset or a fuse on the slide. Any assistance would be appreciated, thanks in advance!
Kkleiber is offline   Reply With Quote
Old 05-04-2014, 11:06 PM   #2
I have a Grey Wolf... but it may be the same... under the undercarriage where the wires go in from the battery mine has two tiny breakers. check there.
eliasj is offline   Reply With Quote
Old 05-07-2014, 10:57 AM   #3
I had the same problem on my flagstaff micro-Lite 18Fbrs. Look under neath and trace the wiring until you run across an in-line fuse. That is where I found mine (toward the front end) . It had blown a 20 amp fuse. It was easy to replace.
lpanthers is offline   Reply With Quote
Old 05-13-2014, 07:02 PM   #4
For what it's worth: I have an '05 FR Grand Surveyor with the enclosed underbelly. I bought this unit knowing that the slide would not work electrically. I had the "I can fix anything attitude". The problem did turn out to be a fuse located near the front of the enclosed underbelly. The factory had actually made a place about 12" square in the aluminum sheeting underbelly for access to and electrical junction box. This square was covered with another piece of this aluminum sheeting and about six pounds of black silicone around the edges. So "Kkleiber" there just may be a fuse near the front of you unit.
Thurman is offline   Reply With Quote
slide, slide out
