Slide out issue
I have a two month old 371rebh and the landing gear and slide outs are doing the intermittent movement thing. When I lower the landing gear all seems to be fine, when I hook up and retract the first one will almost run all the way in but stops, I need to wait 5-10 seconds and it will finish going home, the second one will retract about 3-5" then stop, wait 5-10 seconds and then another 3-5" until it completes. I can here a circuit breaker or selanoid click each time, both when it stops and again before it will start. The same thing happens with the 4 slide outs going in or out. Usually the 1st in the sequence will nearly complete before the routine starts. I've read other forums that talk about the problem and it is fixed by replacing the automatic circuit breaker. I'm not able to locate it and am wondering if anyone knows where it is or if it is integrated with the multidirectional selanoid that the motor is hooked to. It is under warranty but I would like the information when I arrive at the scheduled appointment on May 1st..
