Old 07-07-2014, 11:12 PM   #1
Slide out lost power
Hi folks,
I have a 2011 Wildwood 24tbss. I lost power to slideout and had to close it manually. I have checked all the fuses in the panel and they are good.
I called the factory where it was built in Rialto, CA. They said there might be a breaker behind the fuse box.
Has anybody had this issue?
lic91301 is offline   Reply With Quote
Old 07-08-2014, 12:52 AM   #2
jtstromsburg's Avatar
Start by tracing the wiring from your battery. You should find either an inline fuse or, more likely, a resettable breaker. Be looking for a small cube or rectangle with a tiny black button that may need resetting. Typically, slides and jacks are run straight from the battery instead of the power panel.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 07-11-2014, 10:44 AM   #3
I have the black cube but I do not see a button to reset it. Is it possible it is a one time use?
Woodyee is offline   Reply With Quote
Old 07-11-2014, 10:54 AM   #4
I crawled around underneath the trailer yesterday on a creeper and I couldn't find a resettable fuse. I also opened the fuse panel under the fridge and could not find anything there.
I guess it is a trip to the shop.
power, slide, slide out
