Old 09-05-2012, 07:29 AM   #1
slide out lube
I have a 07 surveyour sv291 wonder how often to lube slide out and how to do it. Use camper about 5 times a year and have owned it for 2 years have never done it? What do you use. Saw dry lube at walmart not sure if good or not. Thanks for the help
campfun is offline   Reply With Quote
Old 09-05-2012, 10:40 AM   #2
lindy's Avatar
I spray mine with a silicone spray about twice a year. I spray the drive gear real good and then down each side of the slide bar.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 09-07-2012, 05:00 AM   #3
Watch out you don't spray too much right before closing slide or DW will probably badger you when slide is reopened and you got streaks on the carpet under the slides.
TV: 2012 Silverado 3500HD DRW Duramax/Allison
FW: 2013 Sandpiper 365SAQ
fschambe is offline   Reply With Quote
Old 09-07-2012, 09:10 PM   #4
Dallas Texas
TexasBBQ's Avatar
Protect all Dry Slide Lube - use once a year. You can find it at RV stores or several places on the net. Use the rubber seal treatment as well.
Product Information - Protect All
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 09-26-2012, 09:00 PM   #5
How are their other products and is their shipping reasonable?
RickV is offline   Reply With Quote
Old 09-27-2012, 04:28 AM   #6
Camco makes a slide lube and is available at walmart. It smells a lot like wd40.
Old 09-27-2012, 07:18 AM   #7
camper007's Avatar
On my FR Salem Villa Estate 39flfb it say's not to lube slide-outs.
camper007 is offline   Reply With Quote
Old 09-28-2012, 12:42 PM   #8
Dallas Texas
TexasBBQ's Avatar
There are a lot of sites that carry it. Some have fair shipping costs, some don't. If that's the only thing you’re going to buy it's probably going to be less expensive to get it at the local camper store. I use the lube and seal treatment. It's good quality product. My unit sat in the Texas sun for about 1.5 years uncovered. The seals had weathered bad from the UV. I washed them and then lathered on the rubber seal treatment. It made a major difference. They're soft, supple, flexible, etc.
2004 Cardinal 33CKT
