Old 07-29-2011, 12:07 PM   #1
Slide-Out Lubrication - Dry Moly Lube
I saw a recommendation to use a dry molybdenum lubricant on the slide-outs. Anyone have any experience with this? From what I have read, this spray goes on wet then dries and forms a lubricating seal.
I bought a can but have not used it yet. Thought I would spray it on an area of the frame and see what it looks like after it dries.
I know the manufacturer says the slide-outs don't require any lube but I use my trailer on the coast and if I don't lube it pretty often, the slides will start making a squealing noise and even trip the auto breaker when it gets bad enough.
I have been using Jig-A-Loo which has worked well but doesn't seem to last long. Always looking for something better.
Dennis
La Vernia, Texas
2007.5 Dodge 3500 Laramie, 4WD, Dually, 6,7L Diesel
2008 Forest River Sandpiper 375QBQ
dd5087 is offline   Reply With Quote
Old 07-30-2011, 06:52 AM   #2
Herk7769's Avatar
Dry Lube is "Da Bomb"!
Anything "gooey" will attract dirt and accelerate wear and noise.
You can also try Slide-Out Dry Lube Protectant - Protect All
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-30-2011, 08:42 AM   #3
Wanna Be Camper
SaskCampers's Avatar
We live in the country on dirt roads and our main slide squealed so bad it scared the dogs. Tried nearly everything to get it to stop and the only thing that worked was Fluidfilm. Sprayed everything down, left it soak for 10 min and then wiped it off, and then put the slide in and out 6 or 7 times and it finally stopped squealing. Talked to the dealer and the svc mgr said they have had the same thing and Fluidfilm was the only thing that worked as well. Haven`t seen any buildup of dirt since either but like I said I wiped it all down after applying it prior to moving the slide. Fluidfilm is one of my favourite products for working on old tractors etc to lube and free up stuff.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 07-30-2011, 11:00 AM   #4
MrT
MrT's Avatar
+1 on the Protect-All product. Works great on my slide.
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
Old 07-30-2011, 11:45 AM   #5
Are you saying that the Moly Lube will be "gooey"?
Dennis
La Vernia, Texas
Old 07-30-2011, 03:14 PM   #6
Herk7769's Avatar
I am not familiar with that product as I use the RV Slide Lube spray.
However Lubing the running grear with grease (like white Lithium or bearing grease) or oiling it with 3 in one or motor oil, will definately qualify as "gooey."
Old 08-03-2011, 12:28 PM   #7
extremebike's Avatar
I use dry moly on the hitch pin and used it for years on the hitch ball when I had a popup. It works great but be sure to shield areas where you don't want the stuff as it will not come off. It goes on wet and 5 minutes later it is completely dry to the touch and will not hold dust. Use cardboard to shield areas when spraying.
extremebike is offline   Reply With Quote
Old 08-04-2011, 08:22 AM   #8
I am going to test the Moly Lube on a small area so I am looking for the Protect-All product locally but have been unable to find it. I know I can buy it on the web but the shipping is expensive. I will keep looking, haven't exhausted all the local stores yet. The Protect-All web site says that Walmart carries it but I have yet to find one that has it. Walmart doesn't even show it on their web site. They only list the Camco product, I have used that and was not impressed.
Dennis
La Vernia, Texas
Old 08-07-2011, 09:26 PM   #9
Interesting thing happened to me today as I was using Protect All Dry Slide Lube... it set my propane detector off... looked at the ingredients and they are using propane as a propellant ...well at least I know the detector works
2010 Rockwood 8281SS Signature Ultra Light
2009 Dodge Ram 2500 w/6.7 Cummins
bobsquarepants is offline   Reply With Quote
Old 08-08-2011, 11:48 AM   #10
Dry moly
LPS makes dry moly and below is the factory link.
LPS Labs:High temperature Lubricants, FORCE 842 Dry Moly Lubricant
Look at the industrial fastener outlets. If they don't have LPS they will have something similar. Good Luck!
Old 10-23-2011, 11:37 PM   #11
before i hit the panic button i need help, i have a 2012 #378 georgetown, i can not seem to find a diagram of how slides work, i'm visualizing on rollers but could be so wrong, my main slide makes a awfully noise like squeaking rollers, so i need to be set straight on that, however here's the biggy, once main slide is all the way in i have notice if i go outside the coach an run my fingers under the slide theres a 1/2" gap up under there, mind you sides an top are tight against coach, when i look up under there it looks warped to me, is that gap normal or should bottom be tight to coach.... right side slide looks same way, got a bad feeling .. HELP please thank you
SEAYALL is offline   Reply With Quote
Old 10-24-2011, 10:09 AM   #12
Anacortesians
There's a vertical "blade" seal on the underside, attached to the sill of the opening in the body. The one on the living room slide on my 325 woks OK, but the shorter one on the bedroom has rolled over along about a third of its length. When the slide is deployed, there's a gap big enough for a squirrel or similar critter to get in. I'm going to rub dry graphite onto the slide's under surface.
I also have some of the inner-wall bulb seals peeling off at the ends. I got some of the 3M weatherseal adhesive to get those stuck back down.
There should be a bulb seal on the flange of the slide which closes any gaps once the slide is all the way in. If yours works like mine, the last half-inch or so of travel on the slide tilts it in at the bottom to close that gap.
Frank and Eileen
No longer RVers or FR owners
