Old 04-13-2015, 11:02 AM   #1
Slide out lubrication instructions
Does anybody know how the slide out bars should be lubricated?
Also, the back gear on the slide out broke when we tried to move the slide out out. Can I replace it myself or is it a service replacement?
Jimbo6 is offline   Reply With Quote
Old 06-06-2015, 08:00 PM   #2
If you're talking about the slide rails with gear teeth on the bottom: I just talked to a service man at the trailer dealer the other day about properly lubrication the slide rails and he said to put the dry lube on all four sides of the bar and the teeth.
wyoman is offline   Reply With Quote
Old 06-06-2015, 09:05 PM   #3
lil2low's Avatar
Dry lube for sure!
lil2low is offline   Reply With Quote
cat, slide, slide out
