Old 07-06-2014, 08:18 PM   #1
Slide out motor
We have a 2012 model 2604 that we just bought used. In moving the slide out in this morning, the motor quit. Where exactly is the manual access to the motor? We have a crank, but no idea of access location.
Also, is there a way to manually work the awning if we have same problem with it in the future.
Dlowery is offline   Reply With Quote
Old 07-06-2014, 08:38 PM   #2
If you look on the awning side somewhere between the back door and the axles, there should be a hole in the skirting, that's where you insert the crank in the manual slide mechanism.
As for the awning...I never myself experience this...I saw something in the manual about it, but can't explain because I'm not sure enough.
Personally , I'm not a big fan of electric awnings, I much prefer the good old manual ones, sturdier,stronger awning arms.
I had 2 2604's...any other questions don't be shy.
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
slide, slide out
