Old 10-01-2018, 06:32 PM   #1
Slide out no power
I have 2016 FR Sunseeker 2400S.
I have read most of past post on slide outs and have checked as I could. Camped this week without problems and closed slide out at campgrounds, when got home to clean unit the slide out doesn't work. When I plugged up AC power heard a beep in camper. Did plug up camper prior to trying slide out, When press button for slide out nothing, no sounds, clicking or movement. i checked the fuses and breakers, I have a breaker near floor under the stove that has a 30 AMP breaker. When I flipped that I got same beep sound. The battery checks to be fully charged.
Any ideas? Do you think the 30 AMP breaker would be the one for slide out? I have checked at battery and can't fine a in line fuse,
wmarion
Navy Retired
wmarion is offline   Reply With Quote
Old 10-01-2018, 07:22 PM   #2
bikendan's Avatar
wmarion
Navy Retired
The slide motor is 12v and has a fuse, not a breaker.
Old 10-01-2018, 07:32 PM   #3
There is a resetable inline fuse close to the battery. It will have a small button on the side. Your slides are 12 volts. No AC breakers involved. you probably held the in button down too long when you closed the slide.
power, slide, slide out
