Old 11-02-2017, 04:17 PM   #1
slide out noise
I have a 2016 gray wolf the kitchen table and couch slid out started vibrating the hole camper when it starts out,the first foot or so then stops. makes no noise or vibration when closing. dealer said four things could be wrong but not what they might be. I bet I have not moved it in and out ten times since I bought it.Its parked on my lake lot and I dont get up to it a lot . HELP !!
mwhalen is offline   Reply With Quote
Old 11-04-2017, 09:03 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. I think what I would do is with it extended check that the gearing has lube (I use dry) and also check that it is adjust up so that the bottom of the box is not rubbing when the slide starts out.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 11-07-2017, 03:25 PM   #3
X2 on SeaDog's post. The slide drops when going out it may be a little to low. Does the interior of the slide seal equally all the way around the interior of the slide when extended?
Rich5117 is offline   Reply With Quote
noise
